20 Most Recent Cyber Acoustics CA-3550 Computer Speakers Questions & Answers
It could be that, or it could be that you have the wrong audio settings. Such as the quality of playback being set too low or a sound setting which is not for music.
Cyber Acoustics... | Answered on Jan 02, 2018
It might be a relay or something that gives click
any way ur speaker power supply need to be checked
Ac to dc converter or transformer r typical cases
Cyber Acoustics... | Answered on Oct 13, 2012
Hello, test your speakers by connecting them to either a radio or a mp3 player/ipod. If you get output from both channels, then it's a computer problem, which might be your Windows 'volume control' settings (in advanced mode you can see the balance control). Alternately, you could plug in a headphone to the pc and hear if you have output to both channels coming from the pc.
If when you test your speakers on a radio or mp3 player you STILL DON'T get an output on the one channel then you need to concentrate your troubleshooting to the speaker system.
Hope this helps...and don't forget to vote!
Regards,
nicam49
Cyber Acoustics... | Answered on Feb 15, 2011
I had the same ones their junk... They don't hace magnetic protection and it says not to put them next to moinitors and other magnetic equpment. The only reason the head phones work is because the cables that send audio signals are still working, It is because the mini sound amps within the speakers have some how distroyed them selves. Its not great and theirs not much you can do acept take it appart and look for either: ( broken/or unsodered wires, or a broken circut). I hope this helps,
TJ
Cyber Acoustics... | Answered on Jun 05, 2010
  1. firstly you check the cable loose/break,
  2. check it by using multimeter
  3. dry soldering, loose contact
  4. resolder soldering points or reconnect cable
  5. your powersupply transformer coil may breaked now it become loose contact.
  6. you check the supply output voltage with and without load
  7. if low or no output voltage replace supply
  8. if you don't get the proper transformer rewind it
  9. also check power amplifier section short ckt
Cyber Acoustics... | Answered on Jun 23, 2008
if you have plugged correctly without any losse contact it should work if not o think your speaker configration is not correctly set go to the control panel->sounds and audio devices->device volume->advanced there u set that balance slider to middle of all volume control,wave,sw synth,line in etc.. then go to speaker settings in the same window of sounds and audio drivers there in speaker settings click on advanced you get another window in that drop down box specify your speaker configration wether is desktop speakers laptop mono speakers or stereo headphones etc specify the right one you have then ok after this in speaker settings click on speaker volume and keep left and right speakers to maximum then apply ok this will work check it out if stil not worked tell me what ws the result ill solve that for u
Cyber Acoustics... | Answered on May 14, 2008
Cyber Acoustics CA-3550 Computer Speakers Logo
21 questions posted
Top Cyber Acoustics Audio Players & Recorders Experts
Ekse
Marvin
Marvin
Paul Bade
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Cyber Acoustics Audio Players & Recorders
Most Popular Question
distorted sound ca 3550
  • Audio Players & Recorders
