20 Most Recent
JVC GR-DVX707 Mini DV Digital Camcorder Questions & Answers
Hi, I have a JVC
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
NO MANUAL
you can search ebay:
http://cgi.ebay.co.uk/MANUAL-FOR-JVC-GR-DVX707-GR-DVX507-GR-DVX407-GR-DVX400_W0QQitemZ270262528178QQcmdZViewItem?hash=item270262528178&_trkparms=72:1300|39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
GRDVX707EK
If the camera becomes damp or cold and brought into a warm atmosphere damp forms in the mechanism which would cause the tape to stick and become damaged or fouled.
leave the camera to warm up for a few hours and the fault should clear.
If not the most common reason is the dew sensor has failed and needs replacing
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
