20 Most Recent Thule 603 Ascent 1500 Questions & Answers
manual
4answers
Cracked thule box
www.recrepair.com is what Thule recommends you use to seal your crack :) -- it is an ABS patch kit and is waterproof as it is used for permanent canoe and kayak repairs. it is NASA designed.
I am using it on my Atlantis 1800.
12/31/2016 1:42:14 AM • Thule Winter... • Answered on Dec 31, 2016
Lid of my 2010 Thule Atlantis 2100 (silver) cargo
Hi there, I believe the silver is paint over black ABS; if so, my repair may help you. A large (8 metre) branch fell on my Thule box splitting the upper carcass in many directions (both seams and field areas), in addition to the complete break of a front lower segment. I decided to try and fix it despite finding a replacement. Well I have to say, it worked out great, and it did not involve expensive epoxy, adhesives, hot air welders, or any of the methods most commonly referred to. Thule's cargo boxes are made from ABS plastic. The same black plastic material used for your household domestic waste plumbing systems. Rather than use foreign (non-ABS) material as your binding agent, simply use ABS. By keeping the joint material native, you are essentially re-establishing the continuity of the original material. Take a small piece of ABS pipe (any scrap will do, just ensure it's ABS -- will say on the side) and grind it down in shavings. I used a rotary cutting tool with a bit that looks like a common router bit for rabbit joinery. This resulted in very small shavings. Accumulate enough shavings and place in a small glass jam jar with a lid. I had to cover roughly 1.5 metres in crack length and found ABS shaving volume equal to a couple marsh mellows to be plenty. Here's the magic.... pour a small amount of Acetone into the jar and stir the contents (do it outside as it fumes) -- add more as needed just to get it to the consistency of carpenter's glue. After you have bound the cracked segments of your Thule from the outside (I used rubberized packing tape as it has great horizontal field strength but can be removed easily). The tape up job doesn't have to be pretty, just ensure the edges are tight together and the tape is firmly holding it tight. On the inside, use a rotary cutting tool and any cutting bit to grind a trough directly where the cracks are. I went down approximately 3 millimetres and across approximately 8 mills. I left it rough to the touch. Clean the trough with Isopropyl alcohol; let dry. Using a small paint brush (ones you find in elementary school water colour paint kits are fine) "paint" the trough with the dissolved ABS from your jar. The advantage here is the Acetone in the mixture dissolves the edge of your trough so both the slurry (your mixture) and the hard carcass body are naturally bonding. As you might imagine, the Acetone will evaporate leaving nothing behind but ABS -- as hard as the original, fully bonded to the original material. Once dried, apply additional coats to build up the trough to your preferred profile. Remove the tape on the outside and you're set. You could apply some sealant to the outer surface of the cracked area, but I did not as keeping it clean to look at on the outside is difficult when adding to the perfectly smooth outer surface.Good luck. lid-2010-thule-atlantis-2100-silver-uj5yyv2q0ahr5z2plldwesul-1-0.jpg
2/6/2015 6:20:41 AM • Thule Winter... • Answered on Feb 06, 2015
How do mount thule 515-0109 bike rack on suburban
It attaches to the factory roof rails if you have them. If your vehicle doesn't have those, then you need the gutter mount feet for your Thule rack.
7/10/2014 4:19:07 PM • Thule Winter... • Answered on Jul 10, 2014
I need mounting instructions for Thule 598
Here is the only manual that thule has.
http://www.thuleracks.com/manuals/598_.pdf
You might want to contact them here on link below.
http://www.thule.com/en/US/Support/Customer%20Service.aspx
1/27/2010 5:33:00 AM • Thule Winter... • Answered on Jan 27, 2010
I have a 2006 Polaris 900rmk snowmobile it keeps overfueling at idle I believe it is one of the injectors on pto side not sure which one of the 2 affects your idle any ideas?
they both can repair manual show how to trouble shoot --------https://snowparts.ru/manuals/Polaris%20Trail%20600-900%20RMK%20Switchback%20Service_Manual_2005.pdf
1/10/2023 1:06:51 PM • Winter Sports • Answered on Jan 10, 2023
No spark on 02 ski doo legend
You have a bad coil or wire.
1/3/2023 2:25:15 AM • Winter Sports • Answered on Jan 03, 2023
2answers
Spark plug gap on a 2006 Polaris 700 Classic
It depends on the brand of spark plug you are using. https://www.google.com/search?q=2006+Polaris+700+Classic+spark+plug+gap ..
12/18/2022 3:53:35 PM • Winter Sports • Answered on Dec 18, 2022
2answers
Wearfit 2.0. Why can't I bind to my iPhone?
Discord users facing issues like How To Fix Discord Not Opening so just make a call on Discord Customer Support 1-802-618-6092 anytime and experts are there on Discord Live Chat to help you 24*7 . Need any kind of guidance to fix the Discord issue so just make a call on Discord customer Service 1-802-618-6092 anytime and fix issues, a helpdesk is there to help you 24*7
2/24/2022 9:59:23 AM • Winter Sports • Answered on Feb 24, 2022
2003 Ski-Doo Grand Touring 550 Fan. All of a sudden I have no spark! What could be the problem?
kill switch --ign switch--cdi--magneto--broken wire --etc https://ski-doo-snowmobile.brssm.com/ https://www.snowmobilerepairmanual.com/ski-doo-repair-manual/
1/16/2022 5:08:05 PM • Winter Sports • Answered on Jan 16, 2022
Skandic Skidoo. How do I take out a battery that is located underneath the seat of a Skandic Skidoo
Question edited for clarity. Question moved from Seat Cars (Spanish car maker and pronounced See-at) to Snowmobiles Category. The are videos and text based articles. The best bet is to fit pigtails to the battery and had a plug for a battery maintainer. You never have to remove the battery, and you never have to worry about it it not being charged. https://www.google.com/search?q=skandic+skidoo+remove+battery ..
1/15/2022 10:33:14 PM • Winter Sports • Answered on Jan 15, 2022
2012 Switchback adventure 600
MAYBE IT NEEDS SOME OIL ADDED
1/4/2022 7:51:27 PM • Winter Sports • Answered on Jan 04, 2022
3answers
What types of waxes are used in cross-country skiing?
There are four different types of waxes that are used: waxtapes, glide waxes, klisters, and kick waxes.
6/25/2021 3:58:02 PM • Winter Sports • Answered on Jun 25, 2021
1991 Polaris Indy 500 Classic. How do you remove the chain case? It seems to be holding on the top?
I fixed the question and put you in the Snowmobile category Video instructions here https://www.google.com/search?q=1991+classic+500+replace+chain ..
6/4/2021 3:46:08 PM • Winter Sports • Answered on Jun 04, 2021
2007 Arctic Cat F1000. Why does it keep stalling while being ridden?
It could be many different items, choke stuck, ignition switch etc. but more importantly have you taken care of your recall? https://www.cpsc.gov/Recalls/2017/Arctic-Cat-Recalls-Snowmobiles
4/29/2021 5:05:37 PM • Winter Sports • Answered on Apr 29, 2021
Ski Doo. Where can I get a repair manual?
Try contacting Ski Doo directly to inquire.
1/23/2021 8:50:35 PM • Winter Sports • Answered on Jan 23, 2021
1996 Yamaha Vmax XT 600 snowmobile. How can I replace speedometer cable?
Unscrew it from the back of the speedometer and follow it back to where the cable terminates at the hub of the track. Undo it there and replace it with the new one. https://www.google.com/search?q=1996+Yamaha+Vmax+XT+600+snowmobile.+How+can+I+replace+speedometer+cable ..
1/19/2021 6:18:29 PM • Winter Sports • Answered on Jan 19, 2021
When do questions usually get answered?
6 months to a year after they are posted. not always but a lot lately !!
12/6/2020 4:58:52 PM • Winter Sports • Answered on Dec 06, 2020
Thule 603 Ascent 1500 Logo
0 questions posted
Top Thule Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
View Most Popular
Thule Winter Sports
  • Thule Winter Sports
Most Popular Question
key broken in box remove locking device
  • Winter Sports
