20 Most Recent Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Questions & Answers
Well...I 'm a girl and i think tribal tattoos are really hot! i would love for my guy to get tribal tattoo designs for men, so I could trace the designs that are across his shoulders, neck, stomach or arm's... with my finger tips i don't really like tattoos but tribal tattoos have something over me. so yes i like full arm tribal tattoos as long as ya don't go over bored ;) I plan on getting a tribal tattoo on my lower back sometime this year.
Kogi l7eh-ta ko... | Answered on Sep 07, 2012
You may try the following steps:
Boot the computer in safe mode.
While booting press the F8 key and on the Windows Advance boot screen, select safe mode and press enter.
Once you are on the logon screen, select Administrator account.
Click on Start and rightl click on My computer, then click properties
Go to hardware tab and click on Device manager.
In the device manager look for Display adapter, Click on the + sign, right click on the listed devices and uninstall.
Now you should be able to boot the computer in normal mode.
Please let me know if you need any further assistance.
If you find this solution helpful, please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
Kogi l7eh-ta ko... | Answered on Jul 08, 2012
Hi.
The solution depends on your graphic card. There are graphic adapters that do not support less than 1280 x 1024. In that case you will really need to replace the monitor.
Try setting the screen resolution from safe mode (see: Change your screen resolution)
If the resolution is restored to 1280x1024 after you set it manually, then you will need to replace the monitor because it is not compatible with the computer. There is no way out as that is the way the technology market works nowadays. Upgrading equipment is a must, not an option.
Regards.
Ginko
Kogi l7eh-ta ko... | Answered on Sep 13, 2011
To change the screen resolution, click on Start - Control Panel - Display - Settings tab and the adjust the screen resolution slider to 1280X1024 click Apply.
Kogi l7eh-ta ko... | Answered on Feb 04, 2011
Your PC video resolution is too high, it should be set to the native resolution of the monitor.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Please leave rating if it helps.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Kogi l7eh-ta ko... | Answered on Jan 19, 2011
If you are sure your graphics card is working ok and the VGA cable is firmly plugged into the monitor and card and the power cable is firmly in the monitor, Id suspect the power capacitors in the monitor are blowing or have blown
Kogi l7eh-ta ko... | Answered on Dec 30, 2010
Check the default power settings. Start -> Control Panel -> System & Maintenance -> Power Options. The default will turn off the monitor from five to fifteen minutes. Moving the mouse should turn it back on. Make sure your video out is activated. On most laptops the key looks like lOl. And its usually in the F4-F8 range
Kogi l7eh-ta ko... | Answered on Sep 05, 2010
Do you get a No Signal on the monitor?
IF so, the problem is in your computer, or you have a bad monitor cable. (Cable from monitor to computer)
Try the monitor on a known working computer, and use that working computer's monitor cable.
Monitor works?
Okay now use the monitor cable from the Dell Inspiron 537.
Monitor works?
Problem is in the computer.
Monitor doesn't work?
Problem is the monitor cable. They do go bad.
Problem is the computer? Check to see how dirty the computer is inside. Unplug the computer from power, open the computer case.
DO NOT reach inside, and touch any components, even to clean, until you have touched the metal frame of the computer case. You are just looking for now.
[ Your body carries Static electricity. Static will fry out the hardware components inside a computer.
Static will do it in a flash, and you won't see it, or feel it!
Computer unplugged from power, you're safe. Touch the metal frame of the open computer case, your computer is safe ]
If the inside of the computer is dirty, so is the power supply. The case fan/s draw air into the computer, and push the air through the computer case.
The power supply fan draws air through the computer, and pushes the air out of the back of the
computer.
Anything that goes through the computer, also goes through the power supply.
Dust, Dirt,. Hair, Lint, Carpet Deodorizer, you name it, can be drawn in. (Sometimes, spiders make webs inside!)
Inside the Dell Inspiron 537 Desktop PC, is a processor with a Heatsink on it, and a Fan on top of the heatsink.
The Heatsink is a square looking device, that has fins on the top.
The bottom is flat, and is attached to the top of the Processor's case.
The heatsink absorbs the heat of the processor, by being in close relation to it, and the fins radiate the heat up, and out.
(What an average Heatsink, and Fan combo look like,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2943299&CatId=493
There is also Thermal Paste, in-between the top of the Processor case, and bottom of the Heatsink)
The fan attached to the top of the Heatsink b-lows the heat away.
If the fins become clogged, and the blades of the fan, the processor heats up.
When the processor becomes too hot, it turns off.
This is a Fail Safe feature that is built-in. BIOS turns the Processor off.
During this, the Processor has been calling for more power, due to the heat.
The power supply tries to keep up.
The power supply has Heatsinks inside it, also. Plus a fan, to draw air across the components inside the power supply.
This is the power supply's cooling system.
Once the fins of the heatsinks become clogged, and the fan blades, the cooling efficiency drops tremendously.
The power supply heats up.
Again, Heat = Wasted Energy.
The power supply tries to put more, and more power out, until eventually the components inside the power supply fail.
Power supply failure is a main cause of computer failure.
Dell Inspiron 537MT Desktop PC Service Manual,
http://support.dell.com/support/edocs/systems/insp535mt/en/sm/index.htm
Dell Inspiron 537ST Desktop PC Service Manual,
http://support.dell.com/support/edocs/systems/insp535st/en/sm/index.htm
Kogi l7eh-ta ko... | Answered on Jul 15, 2010
If the LCD monitor has a faint Windows image, then the LCD monitor has a back-light problem and it could have a faulty inverter board or a faulty CCFL lamp.
Parts and service are available from LCD Parts, their WEB site is :-
www.lcdparts.net
Kogi l7eh-ta ko... | Answered on Jul 12, 2010
Try booting in safe mode per instructions here: http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
You need to find out if the proper video card driver is installed when you use recovery disk. Compaq usually supply separate disk for the drivers.
Try using resolution of 1024x 768 @60 Hz first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Kogi l7eh-ta ko... | Answered on Jun 04, 2010
install an AGP card into an AGP slot then you can see the high resolution. internal display card does not support to high resolution because of insufficient memory .use 8X AGP card for better result
Kogi l7eh-ta ko... | Answered on Apr 13, 2010
It may be that your video card is too old, that probably is the problem since you are running Windows 2k. If not open up your monitor's menu and see if you can manually change the monitor's resolution. Newer monitors do that.
Kogi l7eh-ta ko... | Answered on Apr 12, 2010
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
73 questions posted
Top Kogi Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kogi Computers & Internet
Most Popular Question
l7eh comes
  • Computers & Internet
