20 Most Recent JVC GR-DX307 Mini DV Digital Camcorder Questions & Answers
My camera did the same....it turned out to be a sticking zoom switch. With the camera turned OFF... move the zoom button ON TOP ( above the view finder) of the camera to the left and right about 20 or 30 times... then turn the camera on and try it.... very simple... but it worked for me :o)
Gazza
JVC GR-DX307... • Answered on Jan 16, 2011
san po kaya makakakuha ng drivers nto from pc??pls help
JVC GR-DX307... • Answered on Oct 18, 2010
Hi! The problem will be on the mic itself. You will need to have it replaced for it is not performing well. ONce the mic is replaced a high audio sensitivity will be noticeable. You'll be good after the replacement. Hope this helps and thank you for using FIxYa!
JVC GR-DX307... • Answered on Oct 08, 2010
preciso do programa da JVC GR-DX307 pra fazer o dow
JVC GR-DX307... • Answered on Dec 28, 2008
USB DRIVER GR-D370AG
JVC GR-DX307... • Answered on Dec 14, 2008
Sreejith, I am sorry to hear that you're having this problem with your JVC, it is really a good camera. A possible problem in your camera is the harness that connects the lens can come loose and the camera looses its feedback from the lens position sensor. The lens does not know what position it's in so it defaults to its startup position. I would refer the service to a qualified service tech, there are many items that can be damaged in this camera if it is disassembled incorrectly. Good luck my friend. Joe Weibel Custom Electronics (customelectronics.org)
JVC GR-DX307... • Answered on Aug 21, 2007
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery. Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
JVC GR Video... • Answered on Nov 13, 2017
not sure on this one but it might be the heads in your vid cam may need cleaning. or the tapes are not running straight on the heads or the rollers in side. if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp. try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture. this could also be a head misalignment fault if it is you will have to take it to some one to have a look at. if any of the above does not work then you will have to take to some one to look at it. .
JVC GR Video... • Answered on Nov 27, 2016
Sounds as if the battery needs replacing - have you tried with a spare battery ?
JVC GR Video... • Answered on Oct 08, 2016
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
JVC GR Video... • Answered on Sep 12, 2016
JVC GR-DX307 Mini DV Digital Camcorder Logo
22 questions posted
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Lee Hodgson
Lee Hodgson
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
want download video onto laptop
  • Video Cameras
