20 Most Recent
Sony Handycam CCD-TRV208E Camcorder Questions & Answers
How do I transfer vidoes onto pc with a firewire
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
Cant connect it to my
Your PC must have an analog input in order to accept that kind of signal - they are RCA connections. If you don't have the inputs you can purchase an analog to USB adapter.
Please let me know how
You need to install a video input card into your computer. These are widely and cheaply available for PCs running Windows, and will come with the software required. You can then record the video off the camera or VHS player into a computer file, which you can then copy to a CD later. The card will have sockets for standard RCA plug type analogue video and audio leads.
Error code C:31:22
Try the below instruction first. If it will not help. Please leave a comment.
It keeps flashing c:31:22 whats wrong
This Sony code in your camera is telling you the video heads are dirty, buy or put a cleaning tape in the camera and press play for around 30 seconds, if problem is not resolved use tape cleaner for 30 more sec, that is all it is I assure you.
bye
David
Want film on dvd
you will need a firewire cable (ieee 1394).
you will also need a firewire port on your laptop. if you don't have one the you can buy a firewire pci card.
Error message c:31:23 flashing and unable to take
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
I have a Sony Handycam
Well, for the most part, yes. The analog capture card will allow you to connect the camera to the computer for transfer. You could use something along the line of
this card, but you could also use a
USB Capture device if your system is fast enough - if not, a PCI or even PCI-x card would be better. The last piece of the puzzle would be capturing software in order to make the actual video file itself - both of the links above include some basic software, but you'll need something more along the lines of Adobe Premiere Elements or iMovie (mac) if you want to do any actual editing of the movie.
Please rate this solution if you feel it has helped! Thanks, and good luck!!
Sony handycam CCD-TRV308
i read in a forum somewhere that ppl were having the same issue and their solution was a solid smack on all four sides and everyone who tried it reported success.
Fault code c-31:22
your needs repair in mechanism..Fault given is undetected reel motor rotation .This can be caused by a bad captan motor ,pinch roller bad or bad LS chassis ribbon from upper cassette mechanism.If unit has old type (B) mechanism ,there is a good change LS chassis ribbon is bad .When cassette is inserted and pushed into mech .The latch for LS chassis wears down ribbon and causing a sensor fault ..
Sony DCR-DVD200 camcorder not turning on after trying to fix it.
The best thing you can do now is to take it to a specialist and get them to do the repairs. Camcorders have a lot of electronics in them and can be easily damaged if your a not an experienced repairer. You might also have to consider that this camcorder might not be repairable.
