20 Most Recent Sony DCR-HC65 Mini DV Mini DV Digital Camcorder Questions & Answers
The most likely cause for this is a zoom or focus lens out of place or impaired in some way and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Sony DCR-HC65... • Answered on Aug 12, 2011
try connecting the camcorder to a pc using the cable, sometimes a pc can fix the drive. or you will need to do a factory reset. press in the rest button next to the lcd screen for 3 seconds.
Sony DCR Video... • Answered on Feb 10, 2018
hi, your HDD is either not connected properly or the connector is gone opposite side, please check it and correct, if the error code is showing again go to menu, manage media, then format disk
Sony DCR Video... • Answered on Feb 12, 2016
you will to ontact the customs office in Kiwiland for that answer. In most cases cleaning the hopper in warm soapy water and buying new filters is enough. Some places require a hospital grade detergent such as wESCODYNE be used to include the air hose(s). Please beware, the AC power in AU/NZ is 230 VAC, so you will need a step down power transformer to use it there. (You'd be better off just buying a new one there to be honest, then you needed worry about lugging a heavy power transformer around of changing the plug end to the Clipsal type used in AU/NZ.)
Sony DCR Video... • Answered on Mar 05, 2015
Worth drying another chip.
Sony DCR Video... • Answered on Feb 09, 2015
It could be the bad HDD, look for hdd's for ipod and replace it, they are compatible.
Sony DCR Video... • Answered on May 09, 2014
The only solution I can recommend is to find an iso of the disc, and mount it using DaemonTools in order to run it.
Sony DCR Video... • Answered on Oct 12, 2013
Sony DCR-HC65 Mini DV Mini DV Digital Camcorder Logo
2 questions posted
Top Sony Video Cameras Experts
Jax Planet
Jax Planet
Nasir Muhammad
Nasir Muhammad
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
DCR Sony
  • DCR Sony
Most Popular Question
sony handycam dcr hc65 won 39 t
  • Video Cameras
