20 Most Recent Sony Handycam DCR-TRV240 Digital Camcorder Questions & Answers
well this has been sitting for some time now. but the solution would be wd40! well the straw off of it really, put your roller on and then cut a peice the straw sometimes a can of air staw works to and carefully slide it on.
Sony Handycam... • Answered on Nov 15, 2011
Error code C:31:xx indicates a problem in the cameras tape transport system. This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a defective clutch in the take-up spool or a faulty rotary mode switch. This will require disassembling the camera to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony Handycam... • Answered on Oct 22, 2011
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a dislodged pinch roller, a faulty rotary mode switch or a defective clutch in the take-up spool and will require disassembling the camera to repair. This can usually be done fairly inexpensively. However, it's not a really user serviceable problem and will need to be repaired by a qualified service technician.
Sony Handycam... • Answered on Oct 17, 2011
There are buttons on the side with a + and a -.
Sony Handycam... • Answered on Sep 15, 2011
C31:23 is an error indicating a problem with the mechanism that drives the tape(usually the roller). Open the tape compartment and eject the tape(if any). If you look at the center of the compartment, you will see a roller and a plastic wire kind of thing that may have popped out of its slot. Using a screwdriver or something of the like, gently push down on the wire till it "clicks" into place. Insert a tape and play it to see if the problem is resolved.
Sony Handycam... • Answered on Jul 12, 2011
This is a fault in the tape transport system can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, a dislodged pinch roller or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sony Handycam... • Answered on May 08, 2011
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sony Handycam... • Answered on Apr 01, 2011
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Sony Handycam... • Answered on Mar 15, 2011
Hi!
You may download your handycam's softwares and drivers from this LINK. Always remember that softwares and drivers are limited from the manufacturer's release.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Sony Handycam... • Answered on Feb 26, 2011
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Sony Handycam... • Answered on Jan 31, 2011
Are you looking for Picture Motion Browser software or some thing else for DCR-TRV240 camcorder?
Let me know to help you out.
Thanks.
Sony Handycam... • Answered on Jan 28, 2011
Sony Handycam... • Answered on Nov 18, 2010
This is often caursed by dirt on the capstan that moves the oxide from the tape back onto the heads and bakes hard so these dry tape cleaners wont shift it.
Are you using a shiny type head cart cleaner made of thin tape? if yes get the cleaner tape that is white in colour and like cloth.
Sony Handycam... • Answered on Jun 13, 2010
You can set tape speed SP or LP in record mode only and can not change it in playback mode.
To set tape speed, turn camcorder in camera mode and go to Menu and set SP or LP in record speed option.
Sony Handycam... • Answered on Jan 03, 2010
Sony Handycam DCR-TRV240 Digital Camcorder Logo
36 questions posted
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Richard C Cohen
Richard C Cohen
Lee Hodgson
Lee Hodgson
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
playbacvk intermittent sound occasional
  • Video Cameras
