20 Most Recent Sony Handycam DCR-TRV740 Digital Camcorder Questions & Answers
My Sony DCR-TRV740 camera I just purchased (used), has a playback problem with my 8mm's. When I got the unit I cleaned it well with chamois swaps and MG video cleaner(Recommended by all experts it see
You have a clogged video head. It happens. Do not use the chamois again. Instead, purchase an 8mm head cleaner and give that a try. Only use a brand name cleaner - no generics, and make sure it doesn't come from China!
11/25/2014 4:19:50 PM • Sony Handycam... • Answered on Nov 25, 2014
Having three grey bars when playback
hello, wow .....is it horizontally bar? if yes that mean :1. the head drum have two channel reading that is Ch A and Ch B one of them there a dead channel, try to change head drum that will solve your problem.2. your head drum may dirt, cleaning using paper and alcohol and let it dry naturally. do not insert cassette before you using cleaning cassette. and i hope it will work.thanksotto
10/9/2013 12:56:58 PM • Sony Handycam... • Answered on Oct 09, 2013
Lack of tracking when playing
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
7/30/2011 6:12:35 PM • Sony Handycam... • Answered on Jul 30, 2011
Playback on my sony trv255e
This is usually caused by an oxidized or defective Audio/Video drum. if you have already run a cleaning tape through the camera and this did not solve the problem the camera will need to be repaired qualified service technician.
9/28/2010 10:37:44 PM • Sony Handycam... • Answered on Sep 28, 2010
3answers
Tape won't eject. C:32:11 error message appears.
Hi
Thanks for using FixYa. Try and take the battery out then plug it in to the wall and check if it works. If this doesn’t help then try these steps--
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Also check for a slim "memory" battery. This will fix your C:32:11 and C:32:10 error codes and will allow you to use your Camcorder again.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
1/4/2010 11:03:14 PM • Sony Handycam... • Answered on Jan 04, 2010
The sound is not working when trying to record on
There are 2 heads in the recorder. One for reading (playing) and the other for writing (recording). 1st try cleaning these heads
using a Squab (Q tip) with a alcohol based cleaning solution (Radio Shack). Always rub the squab on the head in the direction the tape would follow, not perpendicular.
7/31/2009 4:12:29 PM • Sony Handycam... • Answered on Jul 31, 2009
4answers
My Sony camcorder DCR-TRV740 has
Hi there
What is the error code and message that appears?
7/31/2009 6:19:52 AM • Sony Handycam... • Answered on Jul 31, 2009
Sony dctrv250 error code C:31:23
I will forward a link to page where you can get more information regarding the issue.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Please try Power Resetting the Camcorder.
First, please turn OFF the Camcorder.
Then, remove the battery pack from the Camcorder.
Then, press and hold the POWER button on the Camcorder for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
7/11/2009 5:42:49 AM • Sony Handycam... • Answered on Jul 11, 2009
Video camera not focusing
hi ! i Jasdeep working with superb broadcast equipments and maintenance as an service engineer where we need to service the camcorders and vtrs of sony.
you need to take it to the nearby service centre .
they will adjust the focus by adjustment remote commander and would not charge you more then their service charges . because nothing is needed to be change in the camcorder they will just put the data by remote commander.
6/27/2009 3:35:48 PM • Sony Handycam... • Answered on Jun 27, 2009
I CAN DOWNLOAD FROM MY MEMORY STICK ,BUT,NOT VIDEOS
first check your meory stic is not virus infected.
Also check that tpye of the file which u copy fromm meory stic it is supported by media player like wav files.
First coonect your camera with usb cable to computer then u find your meory stic as removable disk in my computer
then simply copy those files which u want to copy and paste in computer.
Let me know.
6/4/2009 4:31:58 PM • Sony Handycam... • Answered on Jun 04, 2009
I need dirver Windows Vista 64 bits for Handycam TRV-740
This was taken from Sony's Website....
Driver information for Microsoft® Windows Vista® and Windows® XP
  • The drivers needed to connect most Sony® cameras and camcorders to a computer are already included in the Windows Vista and Windows XP operating systems. With these drivers, you should be able to connect and transfer files to a computer.
  • The USB streaming feature is not supported with the Windows Vista operating system.
  • Detailed Windows Vista compatibility information is available for Sony Cameras and Camcorders.
  • The Windows Vista Starter edition and Windows XP 64-bit operating systems are not supported.
So as you can see...the 64 bit OS is NOT supported.  The only luck you are going to have is either go to XP, Vista 32 bit...or see if there is a 3rd party driver someone made on the internet.  Try google....but I would have to say due to the complex nature of the drivers, it is highly unlikely that anyone has made a driver that is compatible.  It just has to do with how the 64 bit OS is made.  There might be a way to use 32 bit drivers, however you might run into some issues with processing and streaming.  To my knowledge of 64 bit systems, they are backwards compatible with 32 bit applications, so you can use wither 32 or 64 bit drivers....the only downside is by using 32 bit on a 64 bit machine, you are going to suffer a little bit of performance loss.  I hope this answers your questions.
5/30/2009 12:19:30 AM • Sony Handycam... • Answered on May 30, 2009
How do I transfer 8mm & Hi8 tapes to DVD using my computer?
just go to this link:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV740&SelectOS=7
download the usb driver for your camcorder. install. Set power switch to Camera or VCR. Select USB Stream to ON in the menu settings. then connect camcorder to pc.
4/3/2009 3:57:32 AM • Sony Handycam... • Answered on Apr 03, 2009
Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
8/3/2008 9:47:51 PM • Sony Handycam... • Answered on Aug 03, 2008
DCR-TRV740 handycam
heads are dirty , tension may be a little low. worth having Video Tech service in sacramento look at it.
9/18/2007 2:03:20 PM • Sony Handycam... • Answered on Sep 18, 2007
When I turn on the cam corder I can not see the object on the screen.
If you have tried all the settings and still no picture,would suspect ccd sensor faulty,this is a job for qualified engineer
5/20/2007 1:28:44 PM • Sony Handycam... • Answered on May 20, 2007
Sony Handycam DCR-TRV740 Digital Camcorder Logo
36 questions posted
Top Sony Video Cameras Experts
Marvin
Marvin
Jaime Hernandez
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
need dirver windows vista 64 bits
  • Video Cameras
