20 Most Recent LG Flatron 295LM 22" LCD Monitor Questions & Answers
problem with the power unit
LG Flatron 295LM... • Answered on Feb 10, 2014
Hi...there,
Well...you can kicks and screams all you like. It's won't help... It's seems your inverter busted, need to replaced a new ones. Have funs!
U are using a Antenna for free AIR tv correct?Yes?Get a better antenna like a digital antenna should solved this problems,now a day a digital tv and a digital signal pretty strong this day,regular antenna will have this problems,because it tune into a radio waves signal too.
LG Flatron 295LM... • Answered on Jan 18, 2013
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on [email protected]
LG Flatron 295LM... • Answered on Dec 14, 2012
I have a feeling that the monitor has the problem, monitor can take +/- 10% voltage variation.
You said the backligts are on, do they stay on? You should be able to see the glowing screen in the dark room, if it does stay on, then you may have T-CON board problem.
I cannot see how the seller says that it works when the person does not have the power supply to try it out first.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
LG Flatron 295LM... • Answered on May 23, 2011
When it asks for the password enter "7777"
LG Flatron 295LM... • Answered on Mar 15, 2011
its a unique universal code to unlock it,u may find the universal code through the manual of this tv
LG Flatron 295LM... • Answered on Dec 22, 2010
Center pin is positive.
Here are the service manuals:
http://elektrotanya.com/?q=showresult&megnev=LG%20&megnev2=295LM%20&kategoria=monitor&kat2=schematics
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series. Replacement board: http://www.lcdrepair.us
LG Flatron 295LM... • Answered on Dec 03, 2010
you need to set the specs for TMobile and how to add the settings check out this
http://www.mobileslate.com/blog/2009/02/28/lg-cu915-cu920-vu-network-configuration-settings/
read the bottom of the page and it gives the specific Tmobile information
LG Flatron 295LM... • Answered on Sep 06, 2010
Try it on another PC first to narrow down the problem, if it still does not work then you need to open it up.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
LG Flatron 295LM... • Answered on Apr 09, 2010
try resetting the setup i mean setting it up again also what happens when you turn the monitor off and back on
LG Flatron 295LM... • Answered on Apr 05, 2010
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
LG Flatron 295LM... • Answered on Mar 09, 2010
press the function button and the combination fo the key which is mark as blue circle like function key.
LG Flatron 295LM... • Answered on Jan 14, 2010
LG Flatron 295LM 22" LCD Monitor Logo
46 questions posted
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
unlock our
  • Computers & Internet
