20 Most Recent
Sony Handycam DCR-HC90 Mini DV Digital Camcorder Questions & Answers
The language is coming in japanese, want to change
hope yours is not an overseas model.japan made and meant for japanese market at times doesn't have an english language option setting.but lets try to find out and see if this helps.open the lcd panel.touch p-menu (located at the bottom right corner of the lcd screen).then touch menu.(first boxed item at the upper right hand of the screen)..you should see a circle w/icons on it and an up and down arrows at the top and bottom of it.use the arrows to move up or down the menu items.go highlight the icon that has a clock and a globe.now press ok (located at the bootom right side of the screen)it should give you 3 items.last one item is for the language settings.highlight it and press ok again.now,this last part you might need to select one setting at a time (don't forget to press ok once you selected a setting) until you come up w/the english language option. hope this serves you.goodluck.
How do i install cam on my laptop?
hi,
DV cams, doesn't install, it is normally directly recognised as firewire cam (if what you want is to capture the recordings or live), you have to set in your capture program the right device...
now, if what you want is to use the hard disk function (memory stick) you have to light up the camera and then plug it in usb port, windows will recognize it as thumb drive (externat card reader )
I Have a Sony DCR-HC90
USB will only download still photos or movie shorts stored on a card. eg memory stick.
If no card is in the camera then no connection.
If you wish to capture movies stored on the tape, you will require a firewire cable to connect.
Use iMovie to capture the footage or another Mac application like Final Cut if availble on your Mac.
Lens shutter does not open
The lens cover mechanism in these cameras is susceptible to debris and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com
The lense sutter of Sony
Have trouble with the cassette
This is usually caused by a defective tape mechanism position sensor and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
DCR-HC90 thinks unlocked tapes are locked.
the flexwire of the camera at the bottom of the mechanical assembly is already cut..it is need to repair that flexwire or replace the mechanical assembly to sony service center....
Warning message: "Tape is locked--check the tab." Sony DCR-HC90
As you said tape rec tab is not locked yet camcorder says tape is locked.
That means its record protection switch is On for some reason, basically its lever that got stuck/ pressed and need to be pulled up.
Eject tape and check right corner towards you, record switch is located there. Check that lever while tape door is open and look inside that area that is marked in below image that will help you to locate its position, pull its lever upward to release it and insert tape and record.
It is not easy work so be careful not to damage any thing in mechanism.
Hope this info will help you.
Thanks.
I have a 4 year old sony handycam, model dcr-hc90.
This would be highly technical. Not sure of your expertise but since its the main part of a handycam would suggest to either go for a new handycm or get an expert to do it for you.
Remove ALL electrolytic caps. Very carefully inspect underneath caps for trace damage. If there is, install a jumper (esp. under 47uf caps. This will fix your problem. Carefull with this camera, I will not hardly fix them anymore due to main pcb and sensor pcb damage from electrolite. Replace all grip caps and evf will work.
Thanks for contacting Fixya
Sony Handycam DCR-PC1E
Yeah ! Your problem is very simple. u can solve it on your own.
If you dont put the tape the comparment closes well and as soon as you pot the tape the compartment does not close , Right ?
The solution is there within ur hands itself.
If you want the compartment to be closed, then simply dont put the tape inside. let it be outside itself. U see, its so easy !
