20 Most Recent JVC KW-AV50 Questions & Answers
How do you turn off demo mode on a KW-AV50?
How do you make the sound work?
3/13/2016 3:14:02 AM • JVC KW-AV50 • Answered on Mar 13, 2016
Dvd plays but the screen turns off
does it happen as soon as you start driving or even when the engine is switched off?
11/7/2013 11:55:17 AM • JVC KW-AV50 • Answered on Nov 07, 2013
I somehow tried to move from NTSC to PAL, detached the screen and then after turning on, no signal all the time, I can not even listen to radio now. What have I done wrong ?
The good news is that you did not do anything wrong.
The bad news is that this is a common fault with this model and will need to be sent back to the supplier for a firmware upgrade.
Disconnect the unit from the power source for 15 minutes then reconnect and it will come back on, however the problem will come back again as it is a firmware fault.
7/23/2013 10:43:27 PM • JVC KW-AV50 • Answered on Jul 23, 2013
Weak am station
The radio aerial maybe faulty or loose.
3/18/2013 10:17:59 AM • JVC KW-AV50 • Answered on Mar 18, 2013
0answers
Dvd has sound but no picture
Did the unit have a picture before or, is this a new installation?
10/15/2012 4:57:27 PM • JVC KW-AV50 • Answered on Oct 15, 2012
JVC In-Dash CD Receiver - KD-G140. Wiring diagram for kd g 140 JVC please?
Question edited for full 'make model (what it is)'. Installation and User Manual. Wiring diagram is on Page 4. https://www.manualslib.com/manual/81350/Jvc-Kd-G140.html#manual ..
3/31/2024 6:54:49 PM • JVC Car Audio &... • Answered on Mar 31, 2024
JVC KW-V940BW Car Play, Android Audio, Bluetooth and USB stopped working
See page 77 troubleshooting of user manual for help B5A-2488-00_KWV_M_EN.pdf (jvckenwood.com)
2/14/2024 2:14:33 PM • JVC Car Audio &... • Answered on Feb 14, 2024
My JVC KW-XR610 comes on then shuts off just started
See page 4 of manual (Troubleshooting) Install_KW-XR610[J]f.indd (jvc.com)
1/7/2024 10:38:28 AM • JVC Car Audio &... • Answered on Jan 07, 2024
JVC KS 102 car amplifier. Wiring diagram for it please?
Question edited for clarity. Turn question around, add magic word. https://www.google.com/search?q=JVC+KS+102+car+amplifier.+Wiring+diagram ..
12/22/2023 12:59:42 AM • JVC Car Audio &... • Answered on Dec 22, 2023
JVC model kw-av70bt is in production mode how can I change it
Download the user manual and follow corresponding instructions ManualsLib - Makes it easy to find manuals online!
10/11/2023 12:37:03 PM • JVC Car Audio &... • Answered on Oct 11, 2023
Owner manual for Stereo Cassette Deck JVC KD-720
Owner Manual isn't found, as there is a car stereo with a similar number. A standalone Cassette deck only supplies a data signal, so you need and amp. https://www.google.com/search?q=%22JVC+KD-720%22+manual
JVC KD-G720 Instructions Manual
ManualsLib https://www.manualslib.com > manual > Jvc-Kd-G720 View and Download JVC KD-G720 instructions manual online. JVC CD Receiver Instructions. KD-G720 car stereo system pdf manual download. Also for: Kd-ar770, ... Service Manual https://www.hifiengine.com/manual_library/jvc/kd-720.shtml
9/1/2023 12:26:57 AM • JVC Car Audio &... • Answered on Sep 01, 2023
My JVC-SD5 lights up, plays Music, but the lid won't open, any suggestions?
It seems like you're facing a little hiccup with your JVC-SD5. There's some troubleshooting ideas... Firstly, make sure the CD player is powered off and unplugged from the electrical outlet. Safety first, right? Now, take a good look around the edges of the CD lid. Sometimes, dust or debris can accumulate and prevent it from opening smoothly. Grab a soft, lint-free cloth and gently wipe the edges of the lid. Make sure to remove any obstacles that might be blocking it. If that doesn't do the trick, let's try a little trick called the "manual release." Look for a small, pin-sized hole near the CD tray. It's usually located either on the front panel or underneath the CD player. Take a paperclip or a small, pointy object and insert it into that hole. Apply gentle pressure to trigger the manual release mechanism. This should pop open the lid, giving you access to your beloved CDs. Once the lid is open, inspect the CD tray and the surrounding area for any visible signs of damage or obstructions. If everything looks fine, try closing and reopening the lid a few times to see if it starts functioning properly. Sometimes, a little exercise can go a long way in resolving minor glitches. I hope these suggestions help you get your JVC-SD5 back in action and free you from that unwanted station! If you have any more questions or need further assistance, feel free to ask. Good luck!
8/14/2023 7:05:37 PM • JVC Car Audio &... • Answered on Aug 14, 2023
My JVC stereo 6020 not making noise
i kindly recommend that you check volume level is not set to mute.Also,ensure that the stereo is properly connected to the speaker.check if the speaker are working
8/12/2023 5:30:35 AM • JVC Car Audio &... • Answered on Aug 12, 2023
How to reset the clock on a JVC pc-110 boom box 1994 model?
To reset the clock on a JVC PC-110 boombox from 1994, follow these steps:
  1. Press the Clock Set button, located on the top of the boombox, to enter clock setting mode.
  2. Press and hold the Clock Set button until the hour digits on the display start flashing.
  3. Use the Fast Forward and Rewind buttons to adjust the hour to the correct time.
  4. Press the Clock Set button again to move to the minute digits. The minute digits will start flashing.
  5. Use the Fast Forward and Rewind buttons to adjust the minute to the correct time.
  6. Press the Clock Set button one final time to exit clock setting mode and save the new time.
Your JVC PC-110 boombox should now display the correct time.
3/3/2023 6:11:40 PM • JVC Car Audio &... • Answered on Mar 03, 2023
JVC KW-AV50 Logo
8 questions posted
Top JVC Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Car Audio & Video
Most Popular Question
turn off demo mode kw av50
  • Car Audio & Video
