20 Most Recent LG Flatron 995FT 19" CRT Monitor Questions & Answers
3answers
Monitor resolution can't be changed
some 15" monitors do not support 1024 by 768, check your monitor specifications if it does. google on the net with the exact monitor model no. and see if it supports.
1/6/2009 5:30:13 PM • LG Flatron 995FT... • Answered on Jan 06, 2009
LG Flatron L1722P
The computer might not be working properly not the screen... CPU turns - on, but with no response... have the computer check by a computer technician
8/6/2008 8:29:15 AM • LG Flatron 995FT... • Answered on Aug 06, 2008
LG 995FT slightly out of focus
hi
do u have its driver?
send me it to [email protected]
6/4/2008 3:02:35 PM • LG Flatron 995FT... • Answered on Jun 04, 2008
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
5/22/2008 3:15:55 PM • LG Flatron 995FT... • Answered on May 22, 2008
Monitor not work
Try starting your computer in VGA mode (one of the options available from the menu you get if you keep tapping F8 as the computer starts up). In this mode the monitor should work well enough to get to the right resolution. Go to the display settings dialog (right click background and choose Properties, then the Settings tab), and pick the native resolution for your monitor (1280 x1024). Might be worth checking the refresh rate is ok as well before switching to the new resolution (press the Advanced button and the Monitor tab to check this).
1/10/2007 3:15:48 PM • LG Flatron 995FT... • Answered on Jan 10, 2007
Screen problem
Go step by step: 1. maybe you are trying to set a higher resolution then the screen can be 2. its possible that your comp don?t recognize the screen right, check the "display properties" make sure it?s the right model 3. reinstall the drivers. Restart. 4. if its not the software it?s the hardware, try connecting the screen to another computer if it works fine the problem is in the display board . Good luck
2/23/2006 2:14:59 PM • LG Flatron 995FT... • Answered on Feb 23, 2006
Problems with screen
try these options, follow their order, it goes from the easyest and on: 1. every screen has maximum resolution, maybe the resolution you pick is higher than screen possibilities. 2. this may also be a resault of computer not recognizing screen. check windows defenitions, make sure windows recognizes the exact model of your screen. 3. reinstall drivers, reboot. 4. if problem is in hardware, you have to find what part is causing the problems. try connecting the screen to a new computer, try another cable, etc.
2/22/2006 3:02:06 PM • LG Flatron 995FT... • Answered on Feb 22, 2006
LG Flatron W2252TQ does not power up. When I turn the PC on, the blue light momentarily turns on before turning orange and then reverting back to grey.
ok try this one switch the hard-drive off and on again to restart it and then the screen would come one.
7/19/2022 10:19:51 PM • LG Flatron... • Answered on Jul 19, 2022
I was cleaning the screen of my lg flatron w2053tp and the screen went black. The power is on and I can bring up the menus but otherwise nothing
Check the all the cables. Check input settings by using the menu.
8/3/2021 7:29:51 AM • LG Flatron... • Answered on Aug 03, 2021
Hey I have an LG Flatron L1718S screen that work fine for a few weeks then suddenly switch off for a few days ,then switch on again,it's a irritating cycle.Please HELP
  • Larry Ng Jul 15, 2021that is just a YEAR 2007 LCD computer monitor, it needs a computer to work. if it fails in a 2nd PC , if that test fails,the monitor is bad. (hardward failure, monitor. the tests are simple, it fails on 2nd good PC, what can be more simple that test ANY 14 year old monitor on a 2nd good PC. when dead do this.(test2) they are all here when dead again use a FLASH LIGHT. (or in UK a low carbon foot print TORCH)<< joking. https://pcdied.com/monitors_and_screens/... all monitors older than 2010 do this . (has CCFL inside and that is never fun now) the cure is newer monitors 2011 to now called LED monitor.s or OLED. the tubes are cold cathode florescent tubes. (back lamps.) (have 5 classic fail symptoms not just dead) they are short lived, laptops and monitors both back then. 20,00hours on the clock and go bad. bank on it. the 3 failures are CCFL, PSU board, and logic board #1 is CCFL the all died long ago, on average about year 2003 (07 +5= 12, 2012) at 20,000 yours boom dead. or intermittent. PSU is here: https://pcdied.com/monitors_and_screens/... below is logic board. one of the 3 fail, CCFL tubes dead is like 99% we retire them if the CCFL test fails. (using bench PSU to test them) but you have non of that so. upgrade
  • Larry Ng Jul 19, 2021 logic board. (CCFL tubes dead, PSU dead, or logic board dead) and or thermally failing , and bad.
  • Anonymous Jul 23, 2021 99% of all monitors are all dead. due to those silly low live CCFL back lamps. or the 2cards inside that can fail too. PSU card +HV CCLF power or the Data card is dead. 99.9% of folks seen these facts, upgrade now. high voltage inside 600v on the CCFL pins
7/23/2021 3:55:07 PM • LG Flatron... • Answered on Jul 23, 2021
Monitor slow to display picture
Hi, Sounds like an issue of the video card not the monitor. Take to computer shop to verify. One thing you can try is drop the dpi down (refresh rate)a bit. Then try again. If that makes sense to you. Hope that helps.
2/10/2018 9:41:36 AM • LG Flatron... • Answered on Feb 10, 2018
Installing mount on LG Flatron
Hello, It´s not safe to anchor it to the plastic back, monitors usually have a metal frame inside that support the weight of the monitor.
11/12/2017 9:54:47 PM • LG Flatron... • Answered on Nov 12, 2017
Flatron l17175 has it internal wireles receiver
Flatron l17175 what on earth is that? ahhhhhh and LG, lucky Goldstart monitors. not HP. wrong forum Ill move you.
10/16/2017 11:14:22 AM • LG Flatron... • Answered on Oct 16, 2017
0answers
Why does my LG flatron 1953T-BF LCD monitor (19') has no power?
You need to use a ESR meter to check capacitors
3/2/2017 2:27:25 AM • LG Flatron... • Answered on Mar 02, 2017
2answers
Lg flatron e2441 half screen darker
If you get half of the screen darker, remember that LCd monitor have 2 neon lamp at each extremity of the LCD, when one goes out you get this problem. it is possible to replace the LCD neon lamp, I did it many time, but you need to tear all the monitor appart and be carefull not to break any glass while doing so.
8/22/2016 4:20:38 PM • LG Flatron... • Answered on Aug 22, 2016
When ipluh in and switch on my monitor all the screen displays msg analog power saving mode how do i get rid of this and just get to work normally again please help
Normally your computer display goes to sleep mode when the attached cpu is not turned on..
7/29/2016 10:56:18 AM • LG Flatron... • Answered on Jul 29, 2016
Turn on internal wireless receiver
Settings.... Wireless
6/23/2016 3:57:20 PM • LG Flatron... • Answered on Jun 23, 2016
0answers
Range meaning
Be the first to answer 11/9/2015 5:11:21 AM • LG Flatron... • Posted on Nov 09, 2015Be the first to answer
LG Flatron 995FT 19" CRT Monitor Logo
8 questions posted
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Flatron LG
  • Flatron LG
Most Popular Question
lg 995ft slightly out focus
  • Computers & Internet
