20 Most Recent
LG Studioworks 45 14" CRT Monitor Questions & Answers
Diagram for supply
yes the diagram is in book of G.T. hardware engineering college jaypur in rajasthan india the books are available in metro citi and authorised suppliers only in that book not only diagram but troubleshooting mathods are also given
Horizontal and vertical adjustments
Check components related with pots thats adding command ic to pots.If they are ok then change command ic with new one.Before this you can check horizantal hold transistor that is placed on hitsink of eht.small in size and check two small transistor placed near it on pcb.Hope this solution works .If not then i am here
LG studioworks problem of display
this is because some dust might have gone inside your monitor so only you are getting this problem..... If you just remove it. It will work fine..
