20 Most Recent
Philips 170P 17" LCD Monitor Questions & Answers
Problem with Philips 170P5ES: Monitor flashes on and off.
You have a power supply that is about to fail. This is a fairly common issue with monitors after 2-3 years or so of use. The heat buildup in the case causes parts called capacitors to overheat and blow out. If you can solder then you should be able to do the repair yourself. Check our web page at:
www.ccl-la.com click on the link for monitor repair and then the "choose proper parts" link. It will have pictures and explanations of what the parts are and what look for. If you feel you don't want to do the repair yourself we do offer a repair service for $30 part & labor plus return shipping. If you have any questions just let me know via the email link on our web site.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Flickering screen
Yes, right click on the desktop, go to properties > settings > advanced,
Go to the monitor tab and try changing the refresh rate to something a little higher IE if it is set at 60, try 70.
Philips Brilliance 170P
Resolution should be 1280x1024.
Colours 16 bit.
Motherboard drivers installed.
Redo the graphics driver installation by completely removing the current one, and then use the install-CD for the graphics card. The installation could take place while you are in VGA-mode - press F8 during first BIOS-screen - to avoid disturbance.
How to disable theft mode on monitor philips? 276E 4K
The theft deterrence option is available from the SmartControl software that runs on a Windows PC connected to the 276E monitor. See
https://www.usa.philips.com/c-p/276E8VJSB_27/4k-ultra-hd-lcd-monitor/support . Scroll down to the Software & drivers section. Then unzip the file to install it.
Inside the software, the theft deterrence item is under the Options section of the menu. Since a PIN is needed to enable or disable the "feature". It seems unlikely to be enabled accidentally. Did someone else use the monitor for a while? Are you using a different computer with the Philips 276E?
I hope this helps.
11/14/2023 12:35:19 AM •
Philips...
Answered
on Nov 14, 2023
Image flashes for one second on screen then goes away
There could be a few different issues that could cause the behavior you're describing. Here are a few possibilities:
HDMI connection issue: Make sure the HDMI cable is properly connected to both the TV and the laptop. If you're using a HDMI splitter or HDMI switch, make sure those are also properly connected.
HDMI port issue: If you've tried multiple HDMI cables and still have the issue, there could be an issue with the HDMI port on the TV or laptop. You could try a different HDMI port on the TV or laptop, or use a different device to see if the issue persists.
Display settings: Make sure the display settings on the laptop are set to display on the external monitor (the TV in this case). If the laptop is set to display on the built-in monitor, it may cause the display to flash on and off.
Hardware issue: If none of the above solutions help, there could be a hardware issue with the TV or laptop. It's possible that the display controller or other hardware component is faulty and causing the display to flash on and off. In this case, it may be necessary to have the device repaired or replaced.
I hope this helps! If you have any further questions, please don't hesitate to ask.
12/30/2022 2:00:34 AM •
Philips...
Answered
on Dec 30, 2022
I CANNOT PLAY REGION A DVDS ON MY 3D BLU/RAY
No disc in tray Press Home Scroll to settings input code: 13893108520 The settings will pop up and you will see that the DVD region is now set to 0 (meaning region free). I have checked the hack on a BDP8000 (region 2)and it sets the region to 0 (the 7th. digit from the left) alright, but it does not make the player region free as a message from the disc (MGM) comes and tell that the disc is not supposed to be played in this region. The region on the player can be changed to the region by changing the "x" in 138931x8520 to the actual region you want to play.Try this out. The hack codec for blue ray are not yet published so it is not possible to make Blue Rays totally region free as of now.
6/15/2022 12:51:36 PM •
Philips...
Answered
on Jun 15, 2022
Philips streamium bios battery?
NO model toldwell in a shop lacking the $100 service manual what do they do?amazing fact they look inside for any coin cell at alljust look, firstdismantle it look/some have sockets and others are soldered down or , there is no such thing.why not stated what works and does not and ask fordiagnostics help. steps.yes batteries fail, all there not changed out yet?if only remote dead it too has batteriesis UNIT DEAD is screen dead, or stuckis wifi only failing.is it struck in stand by mode?page 33 do the RESET YET?lost AC powerlost AC power pack or using the wrong pACK>water dripped in to the unitlclicker dead.no evidence told so answers will be impossible.Philips NP2500/37 WiFi Internet Radio Network Music Player with Rhapsody my wide guess on real name.did you read trouble page in your lost manual.?but only covers wifi. https://www.download.p4c.philips.com/files/n/np2500_37/np2500_37_dfu_eng.pdf
5/25/2022 1:11:17 PM •
Philips...
Answered
on May 25, 2022
My philips 191EL LED monitor
simply long press input and power touch buttons to reset the ic program and it will be ok be sure to wait 5-10 seconds note: be sure the led has display input and powered on with the problem your encounting thanks ok
5/8/2022 10:20:59 AM •
Philips...
Answered
on May 08, 2022
