20 Most Recent LG L1730S 17" LCD Monitor Questions & Answers
0answers
How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
2/6/2016 4:13:38 PM • LG L1730S 17"... • Answered on Feb 06, 2016
I need setup.exe
Get it from them; www.lg.com/us/support
7/6/2014 12:28:30 PM • LG L1730S 17"... • Answered on Jul 06, 2014
Why doesn't turn my monitor on back from sleep mode?
If from Russia, 8-800-200-76-76 (Russia) 8-820-0071-1111 (Belarus) This is Official LG Support No.
4/28/2014 3:13:42 PM • LG L1730S 17"... • Answered on Apr 28, 2014
2answers
I have lg flatron l1730s
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display.
10/6/2011 8:43:14 AM • LG L1730S 17"... • Answered on Oct 06, 2011
A single vertical line in the centre of the screen
You have bad lcd panel, time for a new one, it will get worst with more lines on the screen.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
9/30/2011 6:02:58 AM • LG L1730S 17"... • Answered on Sep 30, 2011
Win 7 don't recognize the
9/19/2011 7:42:25 AM • LG L1730S 17"... • Answered on Sep 19, 2011
Power board schematic diagram of
Service manuals (one of these should match your chassis)
http://elektrotanya.com/?q=showresult&megnev=lg&megnev2=L1730S&kategoria=&kat2=all
What is it not doing?
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Parts: http://interliquidparts.com/
9/2/2011 6:08:12 PM • LG L1730S 17"... • Answered on Sep 02, 2011
Hi Anand,
You need to check your power options settings and modify it , so that your monitor does not turn off automatically.
If you are using windows xp , go in control panel and then there would be an icon for power options , double click the power options and then you would find settings which read turn off monitor , turn off hard disk etc... select the turn off monitor to never mode or as per your convenience and you would have your problem solved.
Hope this helps.
5/12/2011 11:44:39 AM • LG L1730S 17"... • Answered on May 12, 2011
I have a lg
Common problem: bad caps.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/ Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
1/4/2011 11:04:14 PM • LG L1730S 17"... • Answered on Jan 04, 2011
I didn't get disply on
Connect it to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer's video-adapter is working.
11/6/2010 2:54:07 PM • LG L1730S 17"... • Answered on Nov 06, 2010
Hello there , i d like to express my problem here
Hi
I've repaired a lot of these monitors and every one seemed to do something strange. In this case my first thought is that somehow he monitor firmware got zapped when the card was damaged. Although this could certainly fall into the category of an open ground in the cable. My suggestion at this point would be to take it to a reputable repair person and get their estimate or take a look at www.micromendllc.com.
8/18/2010 9:46:49 PM • LG L1730S 17"... • Answered on Aug 18, 2010
Hello there , i d
there might be a problem with the video cable.borow a cable from a friend and try it.it will work
8/18/2010 9:15:02 PM • LG L1730S 17"... • Answered on Aug 18, 2010
0answers
No power, 5 volts line
Caps look good? it may be in safety shutdown/restart mode. Try heating up the power supply board with hair dryer to see if it will start up, when bad caps are heated up the caps ESR will go down and may allow the power supply to start up. I use 6vdc small lamp attach to the 5vdc so I can see the lamp comes on or not.
http://s807.photobucket.com/home/budm/allalbums
8/5/2010 4:32:42 AM • LG L1730S 17"... • Answered on Aug 05, 2010
Lcd is not on the connect power cable
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
8/4/2010 4:42:08 AM • LG L1730S 17"... • Answered on Aug 04, 2010
LG L1730S 17" LCD Monitor Logo
43 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
need setup exe
  • Computers & Internet
