20 Most Recent
NEC MultiSync LCD1720M (Black) 17 in. Flat Panel LCD Monitor Questions & Answers
LCD computer monitor will not turn on, but just
Can you see a dim image when you view the screen at a sharp angle?
If so you have a backlight problem, the fault could be a faulty inverter that supplies high voltage to the CCFL lamp or the CCFL lamp could be faulty.
Check LCD Parts for parts, service and DIY info Usr this link :-
www.lcdparts.net
I CAN'T READ THE BLUE TEXT IN MY E MAILS
If Blue colors display properly in pictures or graphics check the display and size settings of your computer in relation to the size monitor.
If there is a problem with the blue color because of a problem with the monitor you might be able to compensate for it either with controls on the monitor or with the control software of your video card.
No audio output
Some monitors do no come with built in speakers and a sound system much be purchased to have sound from pc.
What software or cords do I need to get/run in order to get files to transfer to/from the NEC Mobilepro 770, or even get internet?
The NEC Mobilepro 770 is a legacy device that was released in the early 2000s and uses Windows CE as its operating system. Since the device is no longer supported, it may be challenging to find software and drivers that are compatible with modern operating systems like Windows 10. Here are some steps you can take to transfer files and connect to the internet:
- Get the necessary cables: You'll need a USB cable to connect the Mobilepro 770 to your Windows 10 PC. The cable should have a USB Type-A connector on one end and a mini-USB connector on the other.
- Install ActiveSync: ActiveSync is software that allows you to synchronize files between your Mobilepro 770 and your PC. Unfortunately, ActiveSync is no longer available for download from Microsoft, but you may be able to find an archived version of the software on the internet. Install ActiveSync on your Windows 10 PC and connect your Mobilepro 770 to your PC using the USB cable. If the device is recognized, you should be able to transfer files between the two devices.
- Connect to the internet: The Mobilepro 770 has a built-in Ethernet port that you can use to connect to a wired network. To connect to the internet, you'll need an Ethernet cable and a wired network connection. Plug one end of the Ethernet cable into the Mobilepro 770's Ethernet port and the other end into your router or modem. You should be able to browse the internet using the Mobilepro 770's built-in web browser.
- Install additional software: The Mobilepro 770 comes with a basic set of software, but you may want to install additional software to make the device more useful. You can download and install software from the internet, but make sure it's compatible with Windows CE and the Mobilepro 770.
Keep in mind that the Mobilepro 770 is a legacy device, and its performance and capabilities may be limited compared to modern devices. It's also possible that some of the software and drivers you need may no longer be available or supported.
