20 Most Recent
Neovo AG 17" LCD Monitor Questions & Answers
Neovo x17a monitor
Are the settings on the video output correct? Is there a green or orange light illuminated. There is a difference between the Power LED and the Signal LED which is green. If you have no signal the LED will remain orange or yellow but not green. If the LED is green, then a signal is getting from the PC but not necessarily good. Check the signal with another monitor or TV if you can. Check the cable.
F-17 neovo monitor stopped working. power light is flashing yellow
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
The internal circuits are jammed because of electrostatic charges
accumulating on capacitors, or because of a wrong voltage read by the
main chip on your monitor controller board. this started the protection
circuit.
2 The protection circuit detected a wrong voltage or a
broken contact, identified an internal fault and kicked in , starting
the flashing light.
If you are in situation one, then the
monitor will reset just unplugging power cord for one or two hours,
sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common
faults that can occurr suddenly are a blown capacitor on power board,
the inverter board powering up backlight lamp has blown, or a fault on
main lcd controller board.
check also the video cable, if the cable
is shorting, or the connector is bad, you can get same flashing state
because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Regards
I keep getting the blue screen popping up and i
It's commonly known as the blue screen of Death.
It happens for a number of different reasons:
- Your PC is over heating ensure freash air can get in and hot air can escape, your PC components should be free of dust so as to cool the components effectively.
- Ensure that your RAM modules are clean and properly seated in the correct orientation.
- CPU temperature must not exceed 50 degrees centigrade.
- Click here to download CPU temperature monitor.
- Run anti-virus scan.
- Install as many fans as possible, the bigger ones if possible.
But this problem is mostly due to overheating and then the CPU performs a math error and displays a report which is the blue screen of Death!!!
Your timeous rating of my expertise is much appriciated. It's the thumbs up on the top right hand side of this solution.
Thanks
The options menu comes on
The buttons of the monitor are faulty. Open the monitor, use multimeter to find the fautly button and replace it. Probably the buttons Menu and one of the arrows are stuck.
Monitor options flashing on screen how do I remove
It might have a button stuck on it. Does it come on and stay on, or does it come on and go off continuosly?
To exit, press "Auto" once to save changes & return to main screen, push it again to exit the OSD. Assuming everything is functioning properly.
I have a Neovo X-17AV LCD monitor that just went
First of all your VGA cable might be faulty if it is showing you "No signal" Please try to check your LCD menu and try to set some colour bars and audio tone if you get any one of these happen, then your LCD is ok and only the problem is replace your VGA cable.
Please revert back incase you find any issue and next time please write more and in details to understand your problem.
Thanks
Ashish
How do i open the case of my ag monitor?
Every time you purchase any electronic good you get a Manual of that. Since this is very delicate and its locks are hidden, so first get the manual and study that and then slowly unscrew it.Its not very difficult you can do it.
all the best.
thanks
Ashish
AG Neovo X-17a
It sounds like you have a monitor with a common problem. After a few years some LCD monitors
will blow a power supply. The problem is caused by parts called
capacitors overheating in the confined space of the monitor. If you are
good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site
www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
fine. The capacitors do need to be installed with the correct + and -
connections, note the stripe on the old one and insert the new one the
same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.comOver 21 years of computer and printer support/repair
