20 Most Recent
Sharp Viewcam VL-Z5U Mini DV Digital Camcorder Questions & Answers
My tape compartment will not
The most likely cause for this is a defective rotary mode switch in the cameras tape mechanism.
This will require disassembly to repair and can be done fairly inexpensively. However, it's not really a user serviceable problem and should be done by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have it repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
"Dew" sitting on my Video Camera
Dew Formation
• What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
• When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
• How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
• “Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
I need to set time n date. I have no manual. How
power button on to left(camera). press the display button until the mode screen appears. press the up or down arrows to select menu then press the center of the operation button Press the operation button again and execute highlites press oper button again it goes to setting 1.Press arrow up to others 2 press oper button again. arrow down to settingand press oper button again THis gives you the month,press again for day and so on . arrow up or down to change year and time.
How do i transfer the video to my PC.
the way u do it is when u format ur dvd-r u format it hit yes than video do not vr, than yes, when u finallize ur disk u can put it in ur dvd drive and copy and paste the video_ts folder on ur desktop. the vob file is ur movie file that when u double clickon it it starts playing. u dont need nero just put it in ur dvd drive and drag the folder than u can use nero to burn it as a dvd no other conversion need cause the video is already a dvd video u can just pit the dvd in a dvd player and watch it hope it helps
Blue screen
In the playback mode, the screen is suppose to be blue, till you start the tape playing, but if you get the blue screen in the record mode, I have not idea how to help you. You should see what the camera lens see, when in record mode.
Where can I find the PC Connect cable for a Sharp Camcorder Model VL-SD2OU
You may be able to find the PC Connect cable for your Sharp Camcorder Model VL-SD2OU at an electronics store or online retailer that specializes in video and camera equipment. You can also try contacting Sharp directly to see if they have the cable in stock or if they can suggest a retailer that carries it. Alternatively, you may be able to use a generic USB cable to connect your camcorder to your computer, depending on the capabilities of your camcorder and computer.
Keep in mind that you may need to install any necessary software or drivers on your computer before you will be able to access the video files on your camcorder
How can I find a US repair shop to have my Sharp Hi-8 camcorder repaired? A
Newton Ellis & Co. repair most makes and models of camcorders and video cameras. If you are having a problem with your camcorder or video camera then bring or send it in for a free estimate, we can usually give you an idea of what is wrong with it and an idea of the cost. If you can't get in to our shop then give us a call and we will try to help you over the phone or just send an email, see the 'Contact Us' page. We do try to make the repairs as cost effective as possible so if you have an older model then we will try our best to keep the cost down if at all possible.
E commerce Software ecommerce software solution & Online Shopping Cart for small business
https://www.tritansolutions.com/Home/Ecommerce-Solutions
