20 Most Recent Northgate MONNG7NSS 17" Flat Panel LCD Monitor Questions & Answers
Hi
You don't say which operating system you are using.
The monitor resolves images across a fixed range of resolutions and resfresh rates.
It is the resolution of the graphics card or graphics adapter that can be changed, not that of the monitor.
Right click on empty space on your desktop > properties > settings.
Left click and hold on the slider and slide to the right in stages.
Each resolution change offers you a test page to accept or reject.
When satisfied Apply > Yes > Ok.
To reset the Refresh Rate:
Properties > settings > Advanced > Refresh Rate.
Then restart your computer.
Be careful not to exceed the resolution/refresh rate range of your monitor (1280 x 1024) / 75.0 Hz because if you do, when you restart the computer, the monitor will be unable to resolve the image and you will get a blank screen and/or an Out Of Range error message.
An out of range problem might only be resolved by using a different monitor to reset the resolution back to within the range of the preferred monitor.
Hope this helps
Northgate... | Answered on Aug 22, 2011
The frequency of graphic card on your PC cant suffice of what is required by ur monitor.
Or vice-versa / Replace your Graphic Card
Northgate... | Answered on Mar 08, 2011
You have to open uo the set and check for 12vdc feeding the backlight inverter circuits, if you do have 12vdc then the inverter circuits may be bad, also look for bad caps. see example of a couple years old failed monitors: http://s807.photobucket.com/home/budm/allalbums
Northgate... | Answered on Jan 12, 2010
Check the inverter circuit.
Northgate... | Answered on Jan 25, 2009
I had the same problem. power led would flash green for a few minutes then the monitor might come to live. the problem was multiple bad G-LUXON capacitors on the power supply board and inverter. the monitor is full of them. just search online for bad caps and they are near the top of the list. replaced them and it came back to life.
Northgate... | Answered on Jan 14, 2009
Try changing the CMOS battery, and see if the problems go away.
Northgate... | Answered on Aug 07, 2014
You should have mentioned your Operating System, but I would email or call Newegg, and ask them. http://help.newegg.com/app/home/site/US#ContactUsTab
Northgate... | Answered on Jul 30, 2014
Please don't turn it back on. Unplug your computer from the wall and examine the wall socket for blackened or burned sections. It is likely that dust has caused a short in your computer. Sadly, most times this means that you are going to need a new computer or at the very least, some new parts. Take it to a reputable computer repair shop near you and have them test the power supply and other components to see what is salvageable of your computer. With any luck, your hard drive contents MAY have survived but there is no guarantee.
Northgate... | Answered on Mar 27, 2014
"40drhol"? If you are re-installing the OS, when you re-install it will ask if you want to format. If the HDD is not the Primary HDD in your computer. a spare HDD, If the HDD is compatible with your computer interface you can install as a slave/second/primary, depending on the interface/pin outs, or load a different OS on it if you wish and have a Dual-Boot. If it's a second drive in your computer, Open Start Menu, Computer, Select the HDD, just right click and format ,select File System.
Northgate... | Answered on Feb 15, 2013
You need to install the driver of your printer that works with the operating system of your northgate computer. The driver is in the CD/DVD that came with your printer.
After installing everything, you can add RadarSync to your computer to optimize your computer's driver (eg. keeping them updated to avoid from some problems, and running automatic updates so that you can avoid from the headaches of doing the updates manually).
I hope this helps.
If you need more info, please let me know.
Carlo
Northgate... | Answered on Jan 23, 2013
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
You may have to use the XP drivers . there may not be drivers developed yet for the Windows 7.
The manufacturer is the one who supplies compatible drivers to run with the operating system.
Northgate... | Answered on Jun 21, 2011
Go to the control panel and find the system folder then find the device manager then find your sound card and you can load the driver from there. Also make sure your sound is not muted.
Northgate... | Answered on Apr 20, 2011
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
hope this helps
Northgate... | Answered on Mar 27, 2011
Download pc login and burn under nerro burning option ,and restart pc pres F2/F10/Dell boot from cd Insert bootable pc login and it automtically reset your password ,
http://www.windowsreinstall.com/articles/bios/
http://sourceforge.net/projects/pcloginnow/
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Northgate... | Answered on Mar 11, 2011
Does this problem came all of a sudden? Do you hear sounds before? Check the icon with the speaker (or something like this) at the lower right end of the taskbar. Is it marked as forbidden? Click on it and enable sounds.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Northgate... | Answered on Sep 09, 2010
Northgate MONNG7NSS 17" Flat Panel LCD Monitor Logo
9 questions posted
Top Northgate Computers & Internet Experts
Ekse
Carlo Barzo
Carlo Barzo
Tom Chichester
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Northgate Computers & Internet
Most Popular Question
northgate vt7v71 monitor r npower led
  • Computers & Internet
