20 Most Recent
RCA CC9370 Mini DV Digital Camcorder Questions & Answers
JVC safeguard
I MADE MINE WORK!!!! With the camera off, I pressed and held the "play"
button while I powered it on into playback mode. It actually let me
watch the tape. I switched it to "REC" mode and still got the error. So
I switched it off, pushed and held the rec button while powering it
on... IT WORKED. Now I can power it on and off with no more error
messages (so far)! Let me know if this works for you too!
E03 safegaurd mode remove and replace battery? how
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solve the problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC’s and Panasonics and servicing (which may be costly) or scrapping is the only resolution.
The rca camcorder keeps saying
Make sure there is no tape jammed in the mechanism anywhere and carefully clean around the whole tape compartment with cotton buds and isopropyl alcohol to remove any dust and debris, particularly on the opto sensors for read/write and tape present. If this does not solvethe problem, try a different tape and if it does not solve the problem then you will need to get it serviced. This is a real pain problem in JVC's and Panasonics and servicing or scapping is the only resolution.
Safe guard mode, E04
After reading some posts elsewhere, I had one thing work. If you thump the camera on the side outside of the tape itself, it will stop the error message. There is the chance that doing this too many times will render it useless, but for a quick fix I found it worked.
Good Luck
RCA CC604 VHCS Camcorder. My old camcorder won't record?
Question edited into written English with punctuation.
The lens isn't black, the viewfinder is black. Connect it to a television or computer and see if playback and live recording is working. In that way you know the optics and the electronics are working. The viewfinder is a small LCD display screen with a magnifying glass in front of it. Take it to your local camera shop, they will know someone that still repairs these camcorders.
I was hoping to find a free PDF manual as I wondered if there is a switch or a setting to turn OFF the viewfinder?
https://www.google.com/search?q=RCA+CC604+VHCS+Camcorder+manual
2/11/2023 11:54:21 PM •
RCA Video...
Answered
on Feb 11, 2023
RCA CC433 will not record or play back tapes
You can first check for any debris in the video tape player and double check that no settings are stopping the tape from playing (ie a stuck rewind button) . Otherwise, please use the services of geeksquad/bestbuy to refurbish your vcr player. You might also check out BandH (?) video to see if they can refurbish your video tape player.
Thank you.
11/18/2022 6:23:14 AM •
RCA Video...
Answered
on Nov 18, 2022
