20 Most Recent RCA CC6151 Camcorder Questions & Answers
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced. I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar. The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder. The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
RCA CC6151... • Answered on Nov 16, 2017
It is over 18 years old - the probability is that some of the electronic components have deteriorated to such an extent that it is no longer usable.
RCA CC6151... • Answered on Aug 22, 2017
I had one of those and it was so out dated can't get parts. My battery burnt out and could not find a replacement.
RCA CC6151... • Answered on Mar 14, 2017
You can get videos from this camera, or any analogue video source, into a computer. You just have to play them into an analogue video interface port. These are available as expansion slot cards for a PC, or sometimes as a USB plug-in interface. They will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
RCA CC6151... • Answered on Jan 14, 2011
Here's a link to the manual for your camcorder. Take a look at page 11. There are composite (dont confuse with component) audio and video outputs. If your TV has the same type of inputs, then a direct connection between the TV and camcorder is possible. Otherwise, you will need a composite video converter to change the format to a specific channel, usually 3 or 4.
On the VHS adapter, try changing the battery (also in the manual as well) to restore operation.
RCA CC6151... • Answered on Sep 27, 2010
Underneath the black battery, when you take it off to charge, there is another small battery compartment it holds a round battery about an inch in diameter. try replacing it. that might be the problem. hope it works out for you.
RCA CC6151... • Answered on Jun 16, 2008
I don't know anything about the vhs camera - other than they produce superior quality, when they work ok. It would be reasonable to assume the tape transport mechanism would be the same as in a vhs video recorder. I remember an engineer telling me there is a post or protrusion containing a light source and sensor that sometimes fails. The purpose of this is to detect a cassette has been properly loaded into the machine and if it isn't working the machine won't work or only partly work. I think the camera is worth saving but I strongly suggest such specialist equipment should be entrusted to a suitably experienced professional specialist.
RCA Video... • Answered on Mar 02, 2020
Do you have a model number? I found a manual for the RCA Pro8, Pro807, from Voxx here: https://voxxintl.zendesk.com/hc/en-us/articles/225487888-Information-and-Owner-s-Manual-for-the-RCA-PRO8-Model-PRO807-Camcorder . The direct link to this manual appeared as https://sc.voxxintl.com/docs/common/PRO807/PRO807_OM.pdf in my browser history. I hope this helps. Cindy Wells
RCA Video... • Answered on Sep 09, 2018
I am sorry to say that it appears you may have answered your own question, the "hundreds of hours" is the clue. Consider the possibility that your camera is worn out. Sorry.
RCA Video... • Answered on Dec 12, 2017
It appears to have a built-in USB connector, use that.
RCA Video... • Answered on Nov 10, 2017
I understand you have a problem. What is not clear from your description, however, is the actual nature of the problem. Please can you state it more clearly. Thank you.
RCA Video... • Answered on Jun 15, 2017
Won't say what ? Hello ? Goodbye ?
RCA Video... • Answered on Jun 09, 2017
RCA CC6151 Camcorder Logo
Popular Tags
14 questions posted
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
View Most Popular
RCA Video Cameras
  • RCA Video Cameras
Most Popular Question
classic rca autoshot vhs camcorder dsp3
  • Video Cameras
