20 Most Recent Sharp LL173C 17" Flat Panel LCD Monitor Questions & Answers
2answers
Power button won't turn off monitor
Well, I noticed this after I installed win xp sp3. My monitor won't turn offwhen I click the button. I have to set my power setting to a certain timeframe then require a relogin but the monitor just won't turn off otherwise.
8/18/2010 5:37:18 PM • Sharp LL173C 17"... • Answered on Aug 18, 2010
Lcd monitor will not stay on
First thing to try, is to check the cable from Monitor To PC Or Graphics Card.
If you have a loose-broken internal wire, this will be the problem. Dry-Solder Joint et,c.
If the cable, has a socket either end, from monitor to computer.
try to obtain a replacement cable. The second option is to test the output source. i.e Graphics card or output to the monitor.
Hope this helps Mike @ Compurepair.
1/27/2009 1:49:45 AM • Sharp LL173C 17"... • Answered on Jan 27, 2009
2answers
Power button won't turn monitor off?
ok,your monitor is in  a very simple problem.clean the control panel circuit of your monitor,or if it is not working replace the tact switch in your monitor.
9/22/2008 1:25:43 PM • Sharp LL173C 17"... • Answered on Sep 22, 2008
My monitor does not turn on
there is power problem  in your monitor.check the fuse,regulator,and horizontal output transistor
7/17/2008 7:14:29 PM • Sharp LL173C 17"... • Answered on Jul 17, 2008
MONITOR
You will need a TV Tuner expansion card for your computer. If you buy a TV Tuner expansion card and install it, and connect an antenna or cable TV cable, you will be able to watch TV shows on your computer monitor while using your computer. With some TV tuner cards, you can also record TV for watching it later, or even hook up your VCR and record VHS tapes and home videos to put on DVD. This is a more complicated topic and instructions should come with the TV Tuner expansion card you purchase.
TV tuner cards usually run in the range of $20-75 and will fit in most computers. You can buy them online and at computer or electronics stores. Installation is fairly simple and the instructions and software are included (unless you buy a used one)
6/10/2008 10:29:22 PM • Sharp LL173C 17"... • Answered on Jun 10, 2008
2answers
I need the serial number for my sharp copier/printer model number MX C402sc
You will only find that information on the original box it came in, or on the original sales invoice. Other than that, a Sharp engineer might be able to hook up a laptop to it and read it from the EPROM (its programmed memory, the one you are fighting) inside the printer.
11/10/2022 4:09:47 AM • Sharp Computers... • Answered on Nov 10, 2022
Please where is the edit button on sharp zq-520
The E key functions as the Edit key apparently and you press the 2nd key located at the bottom left. https://www.manualslib.com/manual/546173/Sharp-Zq-520.html?page=9#manual
11/8/2022 6:03:03 PM • Sharp Computers... • Answered on Nov 08, 2022
Sharp MX-M356N - CE-00 error.
The fusing unit is defective. Replace the fusing unit.CODE CE-00CE-00CE-00CE-00CE-00CE-00CE-00CE-00CE
11/5/2022 8:01:18 PM • Sharp Computers... • Answered on Nov 05, 2022
Sharp 30C25 network port flashing but the icon on the screen shows the x error, what might the problem?
https://www.youtube.com/watch?v=NCYq2h3B_BA
11/3/2022 1:45:34 PM • Sharp Computers... • Answered on Nov 03, 2022
Sharp mx-m310 error code F9-10
Find out what the code means and repair the fault .
8/11/2022 4:57:23 AM • Sharp Computers... • Answered on Aug 11, 2022
Which specs has the RAM modul in a Sharp UP 810F ?
the manual should cover that, read it yet? it is not a computer at all posted to computer repair help. forum is is Point of Sale terminal, old name Cash Register. age 2008 , only clue is setting date example, RTM) so is 14 years old. not problem stated at all and wants more memory to do what not told, my wild guess is the P O S terminal has amnesia.? it forgets, and you did not read page 3 in the manual these words This POS terminal uses a nickel metal hydride battery pack for memory protection.The battery pack must be replaced at least every three years at the user's expense. this is RECHARGEABLE battery when fails memory dies. until replaced. just line on PCs the coin cell dies, same pain rtm https://www.manualslib.com/manual/324826/Sharp-Up-820f.html?page=3&term=memory&selected=4#manual there is no memory upgrades here, but if do, ask the maker for support. and my be super costly that, a new main board. the list of options from sharp are: this model. For your UP-800F/810F POS terminal, the following options are available: For details, contact your authorized SHARP dealer. Do not try to install any options yourself. 1. External printer model TM-T88III/T88IV, TM-U220/230 or TM-U295* 2. Remote customer display model UP-P20DPB 3. Remote drawer model ER-03/05DWB 4. Remote coin case model ER-48CC2, ER-48CC3 or ER-58CC 5. Remote coin case cover model ER-01CV1-5, ER-02CV1-5 or ER-03CV 6. RAM memory board model UP-S04MB2 (says extra) 7. Magnetic card reader model UP-E13MR3 8. EFT interface model UP-I04EF 9. Contactless clerk keys model UP-R10CL2 * The external printer TM series are not SHARP products there may be 2 choices. now. ask maker SHARP for SUPPORT UP-S04MB2 / S08MB2 Expansion memory board (4MB / 8MB)
7/1/2022 12:22:13 PM • Sharp Computers... • Answered on Jul 01, 2022
Does the Sharp MX-3040N support TLS Security for scan-to-email? I checked the network services and all I saw was a check box to Enable SSL.
It looks like the answer is No. https://www.google.com/search?q=Sharp+MX-+%223040N%22+support+TLS+Security+for+scan-to-email Are you sure you have that model number correct? It isn't showing for a manual and reducing the search query to 'Sharp MX-3040N shows nothing! https://www.google.com/search?q=Sharp+MX-3040N+manual .. ..
4/27/2022 2:03:26 AM • Sharp Computers... • Answered on Apr 27, 2022
Sharp EL-1701C - display issues
No you can buy a used one from eBay $10.00
3/30/2022 8:08:53 PM • Sharp Computers... • Answered on Mar 30, 2022
Hello Have a Sharp Wizard 0z-730
No unless it has a motherboard battery, once you disconnect the power you empty RAM. There appears to be backup software, but you have to backup before you change batteries. Buy an iPhone or iPad mini and it can be automatic. https://www.google.com/search?q=Sharp+Wizard+0z-730 .
3/10/2022 4:09:34 PM • Sharp Computers... • Answered on Mar 10, 2022
Sharp Atomic Alarm Clock SPC325.
go to the al mode and the just tap the set button. If you hold the set button down it will try to set the alarm. so just tap it and it will change one timezone per tap.
2/26/2022 2:23:21 PM • Sharp Computers... • Answered on Feb 26, 2022
Sharp LL173C 17" Flat Panel LCD Monitor Logo
9 questions posted
Top Sharp Computers & Internet Experts
Muzahura Frank
ADMIN Andrew
ADMIN Andrew
Gil Shultz
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
LL Sharp
  • LL Sharp
Most Popular Question
monitor
  • Computers & Internet
