20 Most Recent
SVA-USA VR-15BU 15 in. Flat Panel LCD Monitor Questions & Answers
Monitor problem
Dear Booker3772,
From what you have written I assume you do not have a UPS system protecting the PC.
Unfortunately this mean that hardware has been damaged as electricity spikes have caused electrical stress to the components.
It would be helpfull to me if you where giving me a little bit more information but I will try to help. There are a few possibilities though that can narrow down the problem.
1. When you power up the system nothing happens - No noise no fans nothing. - Solution: The complete PSU or the fuse within is fried. (Change PSU and fire up again)
This is the most likely cause but these are also very possible.
2. When you power up the system the system fans, lights, hard disks make noise but you see nothing in the monitor except the sign. (The monitor's voltage regulation pcb is fried due to the storm) Try with a spare monitor if possible and if possible try the monitor to another PC
3. When you power up the system the system fans, lights, hard disks
make noise but you see nothing in the monitor except the sign. If the monitor works fine, the PSU and the components seem to run fine most likely the components within the PC have been damaged. Not to the extend that a total failure is present but enough to create a mess. Some of the components will still probably be in good condition though. The only way to test them is by interchange one component with another.
In any case if the PC is still under warranty please go to a repair service centre and simply say that it stopped working. Do not mention storms, its your liability normally to protect the PC.
Regards
EngineerGR
My SVA Monitor just started
Unfortunately this isn't a solution but a request for one, as my monitor does the same thing. D: Anyone?
10/13/2011 9:08:55 PM •
SVA-USA...
Answered
on Oct 13, 2011
My sreen is not turning
1st
Check the cable that hooks to the monitor side. Then check it at the
computer side. By check I mean to disconnect it an rehook it up again so
you no it is seated correctly. On some monitors its hard wired so you
cant check the monitor side.
2nd if you have access to a second monitor (after checking the cables on your monitor first).
Disconnect your current monitor and hook up the test monitor. If you
continue to get no signal or picture then you have a defective video
(graphics) card and you will need to replace it.
I hope this helps you out, if it does please give me a YES that I did assist you. Thank you.
4/10/2011 7:53:57 AM •
SVA-USA...
Answered
on Apr 10, 2011
I switched monitors and now
If this is a samsung crt monitor, this is a very common, usually unfixable problem. i reccomend buying an lcd monitor. Dont forget to rate
1/13/2011 3:58:11 PM •
SVA-USA...
Answered
on Jan 13, 2011
When I turn on my
More likely to have bad caps, see examples here:
http://s807.photobucket.com/albums/yy352/budm/SVA%20HM760-B/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
12/16/2010 4:57:40 AM •
SVA-USA...
Answered
on Dec 16, 2010
Flickers
I assume it is an LCD monitor, sounds like you have bad lamp or a lamp power supply. It also could be wrong refresh rate for the monitor, try changing the refresh rate on your computer.
12/19/2009 12:09:50 AM •
SVA-USA...
Answered
on Dec 19, 2009
Installed 19 in tft-lcd monitor on new vista
You need to up the refresh rate. Your settings may be slightly different to mine but this is how I get to it:
- Right-click on the desktop, select Personalize, Display Settings.
- Click Advanced Settings, select Monitor tab.
- Change Screen Refresh Rate to the highest number that is available.
9/9/2009 8:02:50 AM •
SVA-USA...
Answered
on Sep 09, 2009
Resolution goes back to 800X600X75 sva 20" LCD
When you can't change the screen resolution then most likely only the default VGA driver has been installed. You need to install the graphics driver of the video card that is installed in your computer.
To check which graphics driver is installed, click on Control Panel - Display - Settings - Advance - Adapter tab. If the graphics adapter is set for Standard VGA then the graphics driver was not installed.
8/23/2009 8:47:33 AM •
SVA-USA...
Answered
on Aug 23, 2009
COMPUTER HAVE NO SOUND
you need to check to make sure your speaker is off mute and confirm you have the right driver for your sound card by going to controle panel and open up sound/then go to sound and highlight a sound scheme then look for a black arrow going to the right...click and listen for sound..if the arrow remains grey then you don't have the right driver.
9/14/2008 9:21:01 PM •
SVA-USA...
Answered
on Sep 14, 2008
