20 Most Recent SVA-USA VR 17 17" Flat Panel LCD Monitor Questions & Answers
you are a retired electronics service engineer and it has you beat --time to junk it as it must not be repairable
SVA-USA VR 17... | Answered on Apr 18, 2017
A little more information about your requirements on assistance may help.
SVA-USA VR 17... | Answered on Dec 21, 2014
it is because there is no supply to the processor!!
u should try removing and reconnecting the SMPS of your PC which is in the CPU!!
it is mainly because of the smps's loose connecting or a short on the board or in some device connected to the board!!
reply and rate!
SVA-USA VR 17... | Answered on Jul 10, 2010
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
SVA-USA VR 17... | Answered on Oct 25, 2009
all of you mentioned are correct. if they cannot work on color setting of your monitor and for the setting of your resolutions it could be the monitor. the monitor cannot support the color bit mode which required for the windows vista it could be a 16bit color mode which only display for not more than 63herts for the Hi color vsynch compare for the 256color if you have a Hi color settings for about more than 63herst vsynch. it cannot display properly. thanks
SVA-USA VR 17... | Answered on May 11, 2009
the color gray and purper squar color
SVA-USA VR 17... | Answered on Nov 09, 2008
Hi
You say your monitor is now humming. I understand this model has integrated speakers. Have you tried turning the volume on these right down, or even disconnecting the computer from these speakers as they may be picking up a "mains hum" from somewhere.
Hope this is helpful, if so would you please register that with Fixya
Cheers
SVA-USA... | Answered on Mar 02, 2015
Unfortunately this isn't a solution but a request for one, as my monitor does the same thing. D: Anyone?
SVA-USA... | Answered on Oct 13, 2011
1st Check the cable that hooks to the monitor side. Then check it at the computer side. By check I mean to disconnect it an rehook it up again so you no it is seated correctly. On some monitors its hard wired so you cant check the monitor side.
2nd if you have access to a second monitor (after checking the cables on your monitor first). Disconnect your current monitor and hook up the test monitor. If you continue to get no signal or picture then you have a defective video (graphics) card and you will need to replace it.
I hope this helps you out, if it does please give me a YES that I did assist you. Thank you.
SVA-USA... | Answered on Apr 10, 2011
If this is a samsung crt monitor, this is a very common, usually unfixable problem. i reccomend buying an lcd monitor. Dont forget to rate
SVA-USA... | Answered on Jan 13, 2011
More likely to have bad caps, see examples here:
http://s807.photobucket.com/albums/yy352/budm/SVA%20HM760-B/
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SVA-USA... | Answered on Dec 16, 2010
try to check your video card if its installed properly, or clen the surface of the video card to remove the dirt.
SVA-USA... | Answered on Feb 26, 2010
I assume it is an LCD monitor, sounds like you have bad lamp or a lamp power supply. It also could be wrong refresh rate for the monitor, try changing the refresh rate on your computer.
SVA-USA... | Answered on Dec 19, 2009
You need to up the refresh rate. Your settings may be slightly different to mine but this is how I get to it:
  1. Right-click on the desktop, select Personalize, Display Settings.
  2. Click Advanced Settings, select Monitor tab.
  3. Change Screen Refresh Rate to the highest number that is available.
SVA-USA... | Answered on Sep 09, 2009
SVA-USA VR 17 17" Flat Panel LCD Monitor Logo
16 questions posted
Top SVA-USA Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • SVA-USA Computers & Internet
Most Popular Question
unknown mods sva vr17s
  • Computers & Internet
