20 Most Recent SVA-USA VR 17S 17" Flat Panel LCD Monitor Questions & Answers
0answers
0answers
''Out of range'' message on an older SVA monitor
This usually means the display resolution settings on your PC are set too high for the monitor to display the signal. Try lowering the resolution on your PC.
12/21/2014 10:02:57 AM • SVA-USA VR 17S... • Answered on Dec 21, 2014
Looking for drivers to use this monitor with Fedora 20 Linux OS
You don't need drivers. You need to adjust the resolution and refresh rate. If you plug in an old CRT monitor then Linux will probably boot and you can edit the conf file to change the settings. Most LCD monitors require 50-60Hz refresh rate.
5/5/2014 9:14:45 PM • SVA-USA VR 17S... • Answered on May 05, 2014
0answers
Sva manuals
Be the first to answer 1/17/2014 7:45:01 AM • SVA-USA VR 17S... • Posted on Jan 17, 2014Be the first to answer
0answers
Sva manual
Be the first to answer 1/17/2014 7:45:00 AM • SVA-USA VR 17S... • Posted on Jan 17, 2014Be the first to answer
My monitor has power but the screen does not have a display no matter what control buttons I push
When i plugged in my sva lcd monitor it was all black but the green light was on,so i reached around the back and tightened up my cords and it came on :)
3/25/2012 6:30:02 AM • SVA-USA VR 17S... • Answered on Mar 25, 2012
USER Manual For Need a SVA VR-17B LCD Monitor
Did you try their web site? http://www.sva-usa.com/
This is 2005 model so it will be real hard or impossible to get.
Basic LCD monitor and TV troubleshooting guide: http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r7406380-tv_training_manuals Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
6/25/2011 3:32:46 AM • SVA-USA VR 17S... • Answered on Jun 25, 2011
SVA VR-17s, I inadvertantly reversed
It difficult to say what thing or things got damaged when they are reversed biased. If you are lucky it could just be a fuse, otherwise there could be a lot of components that could be damaged by the reversal. Only way to know the extend of the damage is to pop open the case and look inside. I would check if it has a fuse first and the condition of it and look for any obvious parts that were blown up. Unless you know how to troubleshoot electronics, it not worth the trouble to try to see if you can fix it considering how affordable LCD monitors have gotten.
4/21/2011 1:12:51 AM • SVA-USA VR 17S... • Answered on Apr 21, 2011
My screen is green I cant find the menu key on my
You need to find menu button - it's got to be there somewhere. If you do find it, go to the "tools" menu (show a wrench and screwdriver), then select the "RECALL" option. Press then right and/or left arrow on that option. This fixed same problem on my SVA Monitor
Good Luck
12/8/2010 8:35:20 PM • SVA-USA VR 17S... • Answered on Dec 08, 2010
My sva monitor shakes can you help
See solution for "display shivers due to magnatic field"
12/8/2010 8:29:41 PM • SVA-USA VR 17S... • Answered on Dec 08, 2010
2answers
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
12/8/2010 7:06:38 PM • SVA-USA VR 17S... • Answered on Dec 08, 2010
SVA-USA VR 17S 17" Flat Panel LCD Monitor Logo
54 questions posted
Top SVA-USA Computers & Internet Experts
Ekse
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • SVA-USA Computers & Internet
Most Popular Question
sva monitor flickers when turn
  • Computers & Internet
