20 Most Recent
SAMTRON 78DF 17" CRT Monitor Questions & Answers
In my SAMTRON 56V monitor problem
my samtron 56v problem stand by when i power off yet i power on it is off position whats problem with me.switch is many time pressing then is on position.what is parts of my monitr suplly fault.wich part is spoil
Yellow Monitor
Its not something that anyone can do. you'll need to get a new cable and open the monitor to connect it on the inside.
to get the vga connector cable you'll need to make the trip to a repair lab anyway, cause its not the generic kind with pins on both sides that you can get in any general computer store.
Hope you work it out, and don't get yourself zapped please ;]
Samtron monitor is heaving control lock problem
d problem is in a transistor costing little, situated near d monitor's
osd control ic (microprocessor), it is probably short....[refer the
connection n area around the front panel cn connector and crystal clock
generator]..beware u must b a professional
10/29/2009 6:44:29 AM •
Samtron...
Answered
on Oct 29, 2009
Socket Information
They are inputs: Red, Green, Blue, Horizontal & Vertical.
Monitor Mike
1/21/2009 11:15:33 PM •
Samtron...
Answered
on Jan 21, 2009
Monitor Samtron after 10min. looses contact with computer
This problem is caused by the Novatek chip on the video board. Soldering a 50 Ohm Resistor across pins 5 and 6 of this chip resolves the problem on both the Samtron and the Samsung monitors. I have just corrected one of these last night by this means.
Hope that helps
1/12/2009 7:18:56 PM •
Samtron...
Answered
on Jan 12, 2009
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3.
Unplug power cable from LCD, Once power cable is unplugged from LCD,
press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
10/6/2008 8:44:40 AM •
Samtron...
Answered
on Oct 06, 2008
Monitor connection
there is a great possibility that your resolution or refresh rates are set too high for the monitor to display properly... boot the computer in safe mode and change the resolution and refresh rates to a lower setting or the recomended setting for the monitor.. 73 and good luck.
9/17/2008 8:51:36 PM •
Samtron...
Answered
on Sep 17, 2008
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
