20 Most Recent Acer AL1913 (White) Questions & Answers
It wont turn on
Did you move it recently? If you did, you might want to make sure that the plug is all the way in on the back of the monitor, not just having it plugged in to a outlet.
3/16/2016 1:59:24 AM • Acer AL1913... • Answered on Mar 16, 2016
ViewSonic vg2230 back light keeps going off.
Hello, the inverter has gone out. You need to get a new one, but it might be cheaper to buy a new monitor than have it replaced. If you are able to do it yourself look for it on ebay.
11/12/2017 9:58:16 PM • Acer AL... • Answered on Nov 12, 2017
No display
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors - Flickering screen - Screen image disappears after several seconds - Dim screen - Slow start - Power LED on, but no picture - Unusual colors and/or lines The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad. If they appear bulged on top, then they need to be replaced. New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years. Check the cables, connectors and connections. Take it to a repair shop.
4/25/2014 1:41:55 AM • Acer AL... • Answered on Apr 25, 2014
0answers
0answers
Asus windows 7 was hit several times by small
check the fan if it is not block by dirty
8/16/2013 5:37:10 PM • Acer AL... • Answered on Aug 16, 2013
The clock on my computer is always running slow and I have to regularily alter it.
Hi,The only way I can think of to 'fix' a pc clock running slow is to set it to automatically sync with an online clock. You could try a program like NetTime (Link Here) and have it automatically sync it so it's the correct time.
4/17/2013 12:38:10 PM • Acer AL... • Answered on Apr 17, 2013
Back light problem
Back light problem on what
9/30/2012 6:22:35 AM • Acer AL... • Answered on Sep 30, 2012
0answers
Is hp tower compatible with acer keyboard and monitor
yes u can hook any keyboard, mouse, or monitor to any computer
1/29/2012 4:35:32 AM • Acer AL... • Answered on Jan 29, 2012
My new-bought Acer Aspire 3 has yellow acer logo when starting up, is it normal? Because in some yt videos, the acer logo is green
Perfectly normal. It depends on the internal timing of the GPU and the OS version.
4/17/2024 3:01:26 AM • Acer Computers &... • Answered 2 days ago
tip
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
2answers
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER. this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done. Acer X1110 data projector Standard throw projector.. did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2) did you read owners manual page 32 yet, errors. LED codes.? there are 4 LED, and all 4 matter, projector turned (ON) (not one =1) also in pairs glowing and also if blinking or not, so read page 32 it tells all that. my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,. color-undefined-undefined-0.jpg https://manualzz.com/doc/49497108/acer-x1110-user-manual some have dust filtler a shop first cleans is out first, and check fan RPM with and LED tachometer. this is all SOP.
4/2/2024 4:37:58 PM • Acer Computers &... • Answered on Apr 02, 2024
Acer AL1913 (White) Logo
Popular Tags
1 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
wont turn
  • Computers & Internet
