20 Most Recent Samsung SyncMaster 15 GLe (White) 15 in.CRT Conventional Monitor Questions & Answers
If it is samsung TFT monitor problem solution is to press and hold menu buton for more than 10sec.
Good luck.
Samsung... | Answered on Jan 17, 2008
5 year old hyjacker, vinay.
you forgot to say connected to what?
is the screen only dim or dead.? even more important clue.
RTM
read page PDF 17, ?
the OSD screen must work or the monitor is dead
http://downloadcenter.samsung.com/content/UM/201205/20120517112305649/SA10-04Eng.PDF
base pages
https://www.samsung.com/us/support/owners/product/lcd-monitor-a10-series
Samsung... | Answered on Sep 12, 2018
Press the auto key of your monitor to get the best fitted resolution for your window, each monitor has a limited graphic capability of which it is designed. if the production is not ok consult your manufacturer.
Samsung... | Answered on Jul 05, 2016
If your motherboard doesn't have a VGA connection, then that means it most likely does not have an integrated video card. If this is the case, then you will have to purchase and install a video card. It is very easy and your local Best Buy should be a great resource. The geeks there are usually very enthusiastic about explaining how to do it. I use to order from newegg.com, but they have become very commercialized and overpriced, like Best Buy. You can check tigerdirect.com or my favorite Amazon.com. Best Buy will price match any items they sell, including those on Amazon.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_3e83613ef5f2a68b
Samsung... | Answered on Mar 13, 2015
you need to give a bit better details as to what is happening
Samsung... | Answered on Dec 04, 2014
Most new LCD tv and monitors color,brightness,vert.hold, horz.hold,resolution, ect., are all controlled by a single programmed EEPROM, that costs more to replace than a new monitor/tv. You pay for the programming, not the chip.
Samsung... | Answered on Dec 01, 2014
Change the cable and check.
Samsung... | Answered on Oct 19, 2014
Once you power off the monitor you will have to turn it back on. If you keep it in standby mode it will come up once you turn your computer on.
You can boot from a source other than your hard drive, a usb stick or a bootable cd. then use the format command to erase the hard drive. You are now good to give it away.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_e0539de310ea5ad7
Samsung... | Answered on Aug 23, 2014
This could be because the menu button is faulty contact Samsung support and they will help
Samsung... | Answered on Aug 17, 2014
Does this monitor use a separate AC power converter/power supply?
If so, unplug from monitor, and test voltage on the output plug.
Had a similar problem, it was the power supply, NOT the monitor.
Samsung... | Answered on Aug 02, 2014
Samsung SyncMaster 15 GLe (White) 15 in.CRT Conventional Monitor Logo
1 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
control lock
  • Computers & Internet
