20 Most Recent
Belinea 10 17 15 17" LCD Monitor Questions & Answers
IS YELLOW OR GRAY A
Gray is the ground cable..
Please leave me comment, if you need further assistance
RNj VINODKUMAR
Wire a vga cable in backin
in vga connector their are 15 pins .u have to solve this problem u have a digital meter to cheack contunity of the pins. if there is old wire is connected on crt board .first u cheack 0 omhs continutey to 1 pin to 15th pin. then u sold ur new cable
Lcd screen damaged needs replaced
If the screen has a cracked screen - then the LCD display needs to be replaced, but if it has a backlight problem then the fault could be the inverter or the CCFL lamp. These components are cheaper to replace instead of the whole screen.
Check out LCD parts for parts, service and DIY info. Use this link :-
www.lcdparts.net
9/10/2009 4:30:09 AM •
Belinea...
Answered
on Sep 10, 2009
Wireless not working
Make sure the wireless pickup for the laptop, integrated or separate is installed properly and is enabled. The laptop should have a function key (check your manual) like "FN". Pressing this key and usually a function key (F1-F12) should tell you if the wireless function if built in is enabled. If the wireless pickup is USB or a PCMCIA, check the installation again and make sure the hardware is compatible with each other. It's usually not a good idea to mix vendors like using a Linksys router with a Netgear pickup.
8/23/2009 11:14:53 PM •
Belinea...
Answered
on Aug 23, 2009
