20 Most Recent Samsung SyncMaster 174V 17" Flat Panel LCD Monitor Questions & Answers
Look for a brightness control on the monitor itself. If so, use some contact spray to clean it,
Samsung... | Answered on Feb 02, 2018
HI,
What monitor is it?? Does it have software for colour adjustment?
Follow these instructions :
  1. Turn on your Samsung monitor (if it isn't already.)
  2. Press the "AUTO" button on your Samsung monitor. This will run the automatic configuration utility. This will look at your current computer settings and adjust your monitor to best match those. This will take a few seconds. If this has calibrated the monitor to meet your needs, you are finished with the process. If it hasn't, continue to Step 3.
  3. Press the "Menu" button on your Samsung computer monitor.
  4. Use the arrows and the "Enter" button on the monitor to highlight and select various settings categories.
  5. Use the "Brightness" menu on your Samsung monitor to adjust how bright or dark you want the image.
  6. Use the "Colors" menu to adjust how prominent certain colors are displayed on your Samsung monitor.
  7. Use the "Contrast" menu to adjust the level of black on your Samsung monitor.
  8. Select "Save and Exit" to save your changes and exit the Samsung monitor's on Screen menu.
Samsung... | Answered on Dec 24, 2010
REset the screen resolution. I suggest getting the drivers directly from Samsung and then follow thier exact install directions, not plug and play.
Samsung... | Answered on Oct 04, 2010
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Samsung... | Answered on May 23, 2010
press all keys simultaneusly and keep pressed untill the locked massage dissappear and unlocked massage will appear
Samsung... | Answered on Feb 26, 2010
This sounds like a blown power supply. Heat buildup in the monitor case causes parts called capacitors to overheat and blow out. If you can solder then you can do the repair yourself. Check out our web site at: www.ccl-la.com/badcaps.htm We have pictures of what the blown capacitors look like. Open the back of your monitor and look for the blown caps. Replace all the ones that look like the ones in the pictures and you should be back up and running. The values you need to get are going to be marked on the sides of the ones you take out. Be sure to reinstall the new ones with the polarity stripe going the same direction as the old ones come out. You can order replacement parts from several places on the internet or we can supply them for you. You will need to use high temp caps that will be marked 105c, these are not available from Radio Shack. If you use ones that are not rated correctly then you will have more issues in a month or two. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
Samsung... | Answered on Oct 24, 2009
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable The board can run anywhere from $50 on up. Depending on how old your monitor is and how much you've invested into it, you may find it better to just replace it with a gently used one from ebay.
Samsung... | Answered on Jun 06, 2009
check this monitor on another computer.If it is doing same then check power section.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Samsung... | Answered on Jun 08, 2008
check power section.check pf capacitors in this section for ok or replace them.
Samsung... | Answered on Mar 21, 2008
check the section of command.check frontpanel switchs and components related with it. if it dont work then change memory ic.
Looks like we got disconnected during our chat session. I still think it may be those bulbs. If there was any kind of surge, it could have taken them out. I'm looking for specifics on the lamp though. If I find anything, I'll post it here.
Samsung... | Answered on Aug 31, 2007
5 year old hyjacker, vinay.
you forgot to say connected to what?
is the screen only dim or dead.? even more important clue.
RTM
read page PDF 17, ?
the OSD screen must work or the monitor is dead
http://downloadcenter.samsung.com/content/UM/201205/20120517112305649/SA10-04Eng.PDF
base pages
https://www.samsung.com/us/support/owners/product/lcd-monitor-a10-series
Samsung... | Answered on Sep 12, 2018
Samsung SyncMaster 174V 17" Flat Panel LCD Monitor Logo
Popular Tags
25 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
SyncMaster Samsung
  • SyncMaster Samsung
Most Popular Question
replaced emachine monitor samsung
  • Computers & Internet
