20 Most Recent
BenQ P992 19" CRT Monitor Questions & Answers
Colour showing red in the
This could be a sign that your monitor is failing, or that it has been exposed to a magnetic field, usually an unshielded speaker. You can try looking through the monitors settings for something called "degauss" which will shake the display and hopefully remove any distortion caused by a magnetic field. If the monitor does not support this option sometimes leaving the monitor unplugged (power and data) for a day or so will naturally remove the effect of the magnetic field.
hope this was helpful.
Monitor Flashing
Then it goes away? That sounds like the normal degauss feature is working.
Repair power button BENQ G2400WD
It is possible to bridge to another power supply. There are simple tutorials on YT to help and the process is not very invasive, if you do not wish to harm the current bezel. I was unable to find a switch online to match the model number. Maybe try something close enough to match.
