20 Most Recent Cornea CT 1810 18.1" Flat Panel LCD Monitor Questions & Answers
0answers
2answers
Green power light comes on then flashing orange
You need to try it on another PC and also check the VGA cable, if it still does not work, then you will need to open it up if you are going to DIY repair, please read below and look at the pictures so you will know what to look for inside.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
5/7/2010 5:43:37 PM • Cornea CT 1810... • Answered on May 07, 2010
Cornea 1810 monitor power cord
Apparently the monitor's power consumption is near or slightly exceeds the specified value.
My suggestion would be to purchase an adapter with higher rated output current - if for example your original adapter was rated 12V 4.5A, go for a 12V 6A rated adapter. A 30% safety overhead will hopefully contribute to higher reliability.
11/18/2009 8:40:20 PM • Cornea CT 1810... • Answered on Nov 18, 2009
2answers
Power supply
Bs more specific with your problem.
12/10/2007 3:50:07 PM • Cornea CT 1810... • Answered on Dec 10, 2007
0answers
The screen keeps turning on and off. It stays on
my screen is doing the same thing
2/2/2010 10:30:01 PM • Cornea Computers... • Answered on Feb 02, 2010
Display is flashing on and off
Since the display is flashing on and off, try it again on both computers and if the flashing stills goes on then you know that the monitor is bad cause there is no way to video cards from two different computers are going to have the same problem.
8/3/2009 10:50:23 AM • Cornea Computers... • Answered on Aug 03, 2009
2answers
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered 2 hours ago
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/15/2024 4:17:35 AM • Computers &... • Answered Yesterday
How to get free backlinks?
YouTube Backlink Generator https://ovdss.com/apps/youtube-backlink-generator
4/13/2024 3:06:42 PM • Computers &... • Answered 3 days ago
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
4/13/2024 2:31:14 PM • Computers &... • Answered 3 days ago
3answers
How i free download tally
u need tally 4.5 free software (full ) if u need mail me i will give u link k
4/13/2024 2:20:33 PM • Computers &... • Answered 3 days ago
We have a Dukane Model No ACC5 Administrative Control Console and it keeps chirping. Not sure why or how to make it stop. Please advise?
This fault / alarm / warning is not listed anywhere and the company is no longer in business. Turn over the console and see if there is a door for a back up battery. It may be warning that it is running out. Do the same with the main control unit. You could also try powering off the main unit for 10 minutes to reset the software. https://www.google.com/search?q=dukane+model+no+acc5+administrative+control+console+chirping This is the unit that drives your admin console http://serialsistemas.com.br/duk/2/85101-0025%20--%20MCS350.pdf ..
4/12/2024 2:30:20 AM • Computers &... • Answered on Apr 12, 2024
2answers
To check if my sasseta certificate is registered
http://www.sasseta.org.za/ SASSETA Branch Contact Details Telephone Numbers: Call Centre: 27 (0)11 087 5555 Fax Number: 27 (0)11 205 0046 Switchboard: Midrand E-Mail: [email protected] Address & Map: Midrand Office Physical Address: Riverview Office Park Janadel Avenue (off Bekker road) Halfway Gardens Midrand 1685 Postal Address: P.O. Box 7612 Halfway House 1685 http://www.sasseta.org.za/content/tinymce/plugins/openfile/uploads/FRM_SKA_004_Application%20for%20Certificate%20Re-Issue.pdf
4/12/2024 12:53:51 AM • Computers &... • Answered on Apr 12, 2024
Would you want my fix for empowering technology pop up?
Removing/uninstalling empowering technology popup
BleepingComputer https://www.bleepingcomputer.com > forums > removin... Jul 30, 2020 - This annoying pop up started yesterday, it cannot be stopped. It blinks like a turning signal now. I looked everywhere for a fix or info on ... ..
4/11/2024 9:10:48 PM • Computers &... • Answered on Apr 11, 2024
Can I play Minecraft in my PC?
If it is installed, probably.
4/11/2024 8:56:02 PM • Computers &... • Answered on Apr 11, 2024
Je recherche le service manuel ou diagram beringer pmp1000 merci
Salut! Je pense que c'est le manuel que tu recherches? https://www.manualslib.com/manual/214305/Behringer-Europower-Pmp1000.html
4/11/2024 3:05:34 PM • Computers &... • Answered on Apr 11, 2024
SERIAL NUMBERS DO KARAOKE VIDEO CREATOR?
You have the software, if it is not stolen or bootlegged, you have the numbers to authorise it.
4/10/2024 5:34:15 PM • Computers &... • Answered on Apr 10, 2024
Cornea CT 1810 18.1" Flat Panel LCD Monitor Logo
Popular Tags
6 questions posted
Top Cornea Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cornea Computers & Internet
Most Popular Question
cornea 1810 monitor power cord
  • Computers & Internet
