20 Most Recent Canon ZR25MC Mini DV Digital Camcorder Questions & Answers
Not sure where you are located, but we have several used lens caps for that camcorder. You can get our phone number from our website, if you have not found one yet.
Hope this helps.
www.austintelstarservices.com
Canon ZR25MC... • Answered on Jul 23, 2011
Parulanu95, I have a blinking red light in the upper right quadrant. It looks like a broken flower in a rectangular flowerpot. I have no idea what it is. Did you ever find out?
Canon ZR25MC... • Answered on May 29, 2011
This is a fault in the tape transport system can be caused by several problems including the transmission gear in the tape mechanism not engaging properly, adisloged pinch roller or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Canon ZR25MC... • Answered on Apr 27, 2011
This is most likely caused by a damaged or misaligned audio/video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Canon ZR25MC... • Answered on Mar 18, 2011
Canon no longer repairs the ZR25MC. It is on there list of discontinued service items.However, I do, as long as the image sensor is good. This part is no longer available from any source. I have a supply of parts in stock and would be happy to take a look at the camera for you.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Canon ZR25MC... • Answered on Mar 10, 2011
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Canon ZR25MC... • Answered on Jan 02, 2011
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
Canon ZR25MC... • Answered on Nov 18, 2010
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Canon ZR25MC... • Answered on Oct 29, 2010
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape.
Canon ZR25MC... • Answered on Sep 09, 2009
try opening the camera and removing the tape.
Are the reel motor tops OK? Does it look like they seat inside the cassette properly or are the tops at a silly angle or missing?
Look at the mech in particular at the tape path. Is there a buildup of muck on any of the posts, head, pinch roller etc?
Clean this off with IPA alcohol on a cotton bud and leave to dry 1st before trying another tape
Canon ZR25MC... • Answered on Aug 24, 2009
The tape can't eject.
Canon ZR25MC... • Answered on Aug 23, 2008
It could be a head adjustment or it could be the CCD unit. It should be taken in for repair to find the cause.
Canon ZR25MC... • Answered on Jul 13, 2008
The best way to get it out is take it to a camera shop of Best Buy. They didn't put a manual eject on the player. If you take it into a shop they should know what to do.
Once it's out clean the heads with a DV tape cleaner.
Try changing the CR2025 cell beneath the battery. Also, I have had problems when the battery on my remote got low and sent odd signals, Try changing those or just removing them, unlss the remote was nowhere near the camcorder.
Canon ZR25MC... • Answered on Apr 28, 2008
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Canon ZR25MC... • Answered on May 13, 2007
Had the same problem, usually when trying to upscale video ! Try reducing size of video on laptop when using transfer software, see if that helps. With my aged laptop, problem seems to be because my laptop has an extremely slow processor chip, and it just can't keep up with the video ! The software I use, which is free, is Freemake Video Convertor, which gives you a choice of output formats and sizes.
Canon ZR Video... • Answered on Mar 16, 2016
Canon ZR25MC Mini DV Digital Camcorder Logo
22 questions posted
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
red light blinking screen
  • Video Cameras
