20 Most Recent CTX Professional PureFlat PR960FL 19 in.CRT Conventional Monitor Questions & Answers
hi try lighten up the whole screen - its the "sun" icon and raise the contrast - its the half black hlaf white circle icon if it dont work , give us more details hope i helped
CTX Professional... | Answered on Apr 28, 2008
https://www.google.com/search?source=hp&ei=dLc1XsSKOsualwS5nIuACQ&q=For+the+ctx+s510ba+to+work+does+it+have+to+be+online&oq=For+the+ctx+s510ba+to+work+does+it+have+to+be+online&gs_l=psy-ab.3...1484.1484..2223...0.0..0.255.255.2-1......0....2j1..gws-wiz.avrp5RVpmTU&ved=0ahUKEwjElNG08rDnAhVLzYUKHTnOApAQ4dUDCAU&uact=5#kpvalbx=_d7c1XpKjKYqh1fAPmLiYkAs43
CTX Computers &... | Answered on Feb 01, 2020
What you need to Turn On?
CTX Computers &... | Answered on Jul 14, 2012
Go to manufacturers for support.
CTX Computers &... | Answered on Apr 04, 2012
Here is a website which has a great pic:
http://www.processor.biz.ua/product/web-kamera-a4-tech-pk-635m-/
If this helps, please leave a great review. Thanks for using Fixya!
CTX Computers &... | Answered on Sep 22, 2011
If you are not able to oepn yahoo mail you may do the following steps below.
1) Click on "Tools" in the menu bar at the top of your browser.
2) Select "Internet Options".
3) Under the "Temporary Internet Files" box, click on the "Delete Files" button.
4) Click OK.
5) Click on the "Settings.." button.
6) Under the section "Check for newer versions of stored pages," select
"Every visit to the page."
7) Click OK.
8) Click OK.
9) Refresh / Reload your browser.
CTX Computers &... | Answered on Mar 21, 2011
check the signal cable n ensure its properly connected and try changing it if possible to confirm the problem
CTX Computers &... | Answered on Aug 02, 2010
First make sure graphic driver works fine and resolution is set to proper resolution.
For that when you power up the computer press F8 key then enter in "Enable vga mode" then go to start menu->control panel->display property ->settings change screen resolution to 1024*768 then apply and ok.
if still same issue then uninstall graphic driver then reinstall.
If still same then you need to change monitor if you are not able to reset settings of monitor to factory defaults.
Let me know if you need further assistance.
Thanks for using FixYa.
CTX Computers &... | Answered on Jan 22, 2010
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
You need a new screen surface...you can order one from any reputable dealer....just take your monitor apart and unattach all of the components and replace the screen area with the appropriate part. You are not specifying whether or not it's an LCD or a CRT...if it's a CRT just go buy a new one :) if it's an LCD you can replace the screen for 100 dollars or so.
CTX Computers &... | Answered on Dec 15, 2009
glenn659, possible cause is bad internal switch-mode-power-supply" failure or SMPS is detecting something wrong with lcd cold-cathode-fluorescent-tube backlighting circuit, (INVERTER) and it goes into SHUTDOWN mode to try and prevent a catastrophic failure from occuring. Glenn, visit youtube, search for video clips on LCD monitor disassembly and also also research BAD Capacitors or Swollen Capacitors and also the "WHY DO LCD MONITORS FAIL PREMATURELY" Certainly your's will be in the top two causes! Did you do the flashlight test with your monitor "on" and connected to a known good PC with the WIN-desktop screen showing. Even though screen is BLACK it might still show the desktop when you hold the light about 1" from screen. Some will, some won't depends on condition of the power supply. In any case get back to me with your plan of action you intend to take after viewing YOUTUBE stuff. Bye for now. I'm louie12fix on fixya or [email protected]
CTX Computers &... | Answered on Oct 02, 2009
i got my bracket for mine at office depot and circuit city also caries them
CTX Computers &... | Answered on Aug 22, 2008
If you are referring to a conventional CRT monitor, then the fault you have described is indicative of a cold solder in the vertical section. Often, this would be any of the pins of the vertical IC. The vertical IC is the only IC that is heatsinked and sits at the back of the flyback transformer.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
CTX Computers &... | Answered on Aug 19, 2008
What are tearing lines?
CTX Computers &... | Answered on May 29, 2008
heres a suggestion go back to xp service pack 2. service pack is very easy to use and more compatibility than sp3. right now my 10 pc's are all xp sp2 and they have no problems about the sound.hope that helps
CHARCOIS
Computers &... | Answered 38 minutes ago
CTX Professional PureFlat PR960FL 19 in.CRT Conventional Monitor Logo
1 questions posted
Top CTX Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Ekse
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • CTX Computers & Internet
Most Popular Question
colour adjustment
  • Computers & Internet
