20 Most Recent Canon Elura 50 Mini DV Digital Camcorder Questions & Answers
Elura 50 record direct to SD card
There may be a YouTube video that will help with this
6/30/2017 12:57:24 PM • Canon Elura 50... • Answered on Jun 30, 2017
5answers
Condensation Detected ......... Remove the Cassette
People, I got the same problem like 5 minutes ago, but I fixed it. You have to REMOVE the battery while the camera is off, then wait 2 seconds and take it back inside. It works.
But I have an Canon Xm1, so I don`t know if it works for all of you guys, but good luck!!
[email protected]
11/15/2012 11:17:24 AM • Canon Elura 50... • Answered on Nov 15, 2012
Canon elura 50 keeps rejecting the tape
tape door keep eject
6/27/2012 5:15:46 PM • Canon Elura 50... • Answered on Jun 27, 2012
My camcorder will not record
My Canon Elura50 did the same. It's a manufacturing defect with the CCD, (The image sensor) mount installed by Sony Corp.
Canon Service centers hounour a full repair of this problem free of charge. You just have to find one close and take it in for "CCD problem"
Incidentally Canon has about twenty or thirty cameras with this same problem. Everything works but there is no image. It's the Sony CCD mount inside Canon Cameras.
Trust me, It's 100% free repair.
4/22/2011 8:10:20 AM • Canon Elura 50... • Answered on Apr 22, 2011
When I turn the camera on and put it in camera
Your CCD (Charge Coupled device) is faulty and requires replacing. This was a known fault a few years ago and free repairs were available. This is not likely to be the case now.
3/9/2011 8:51:59 PM • Canon Elura 50... • Answered on Mar 09, 2011
Condensation detected
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
10/18/2010 5:19:54 PM • Canon Elura 50... • Answered on Oct 18, 2010
I lost my elura 50 digatal video camcorder manual
You can download the Instruction Manual here.
10/29/2009 11:54:48 AM • Canon Elura 50... • Answered on Oct 29, 2009
My tapes keep getting rejected
it could be a tight tape witch case it will just spit it back at you
the other thing it could be is the battrey is getting down
10/26/2009 9:53:01 PM • Canon Elura 50... • Answered on Oct 26, 2009
Muddy image on screen and recorded
You are in luck. Sorry for the trouble but your model Elura 50 still has the CCD advisory from the factory for free repair. Send it in for CCD advisory before it is too late! When all functions are working but has distorted image in camera mode is due to CCD chip. Good Luck -James. for further assitance email, go to www.camerarepairjapan.com
5/7/2009 1:38:42 AM • Canon Elura 50... • Answered on May 07, 2009
2answers
Flashing red icon in screen with Canon Elura 50
your battery is missing or in wrong or dead
6/6/2008 6:28:42 AM • Canon Elura 50... • Answered on Jun 06, 2008
How to remove a tape out of a canon es55 that will not power up even if the battery is charged
If you suspect that your JVC camcorder may have been damaged by plugging in the wrong power cord, it's possible that the cassette mechanism may not release as intended. However, you can try the following steps to manually release the cassette:
  1. Turn off the camcorder: Make sure the camcorder is turned off and unplugged from any power source.
  2. Locate the cassette release button: The cassette release button is usually located on the side or bottom of the camcorder near the cassette compartment. It may be labeled "eject" or have a symbol that looks like a triangle with an arrow pointing up.
  3. Press the cassette release button: Press and hold the cassette release button for several seconds to see if it releases the cassette. You may need to press it firmly or use a pointed object like a pen or pencil to press it.
  4. Manually release the cassette: If the cassette release button does not work, you can try manually releasing the cassette. Look for a small hole on the camcorder near the cassette compartment. This hole may be labeled "emergency release" or have a symbol that looks like a triangle with an arrow pointing down. Insert a straightened paperclip or similar object into the hole and press gently to release the cassette.
If you are unable to manually release the cassette, it's possible that the camcorder has been damaged beyond repair.
2/22/2023 9:34:00 AM • Canon Video... • Answered on Feb 22, 2023
My Canon ZR-40 Mini DV Camcorder only has a blank screen when in VCR mode. Cannot use any VCR functions. When I try to record, it says 'No Card' but there is no slot for an SD card at all.
It's possible that the video head is dirty or damaged, which is preventing the camcorder from playing back tapes. You may need to clean or replace the video head. As for the "No Card" message, it may be a default message that appears when the camcorder cannot detect a tape. Check that the tape is inserted correctly and try a different tape to see if the issue persists. If the problem continues, it may be a more serious issue with the camcorder that requires professional repair.
2/14/2023 8:31:25 AM • Canon Video... • Answered on Feb 14, 2023
My CANON MV940 DIGITAL VIDEO CAMCORDER cant charge.....when i plug it in the battery charge indicator does not flash or light up
If your Canon MV940 digital video camcorder is not charging when you plug it in, there are a few things you can check to try to determine the cause of the issue:
  1. Check the power adapter: Make sure that the power adapter is securely plugged into the camcorder and that the outlet you are using is working. Also, check that the adapter is not damaged or malfunctioning.
  2. Check the battery: Make sure that the battery is inserted correctly and that it is not damaged or worn out. If the battery is old or has been used for a long time, it may no longer hold a charge and will need to be replaced.
  3. Check the charging port: Make sure that the charging port on the camcorder is clean and free of debris. If there is debris blocking the port, use a soft-bristled brush or a can of compressed air to clean it out.
  4. Check the battery terminals: Make sure that the terminals on the battery are clean and free of debris or oxidation. Clean the terminals using a soft-bristled brush or a pencil eraser.
  5. Check the firmware: If the problem persists, check to see if your camcorder's firmware is up to date. If it isn't, update it.
If you've tried all of these steps and you still cannot charge your camcorder, it's possible that there is a hardware issue with the camera. In this case, you may need to contact Canon support for further assistance. https://amzn.to/3WisSDI
1/16/2023 6:03:24 AM • Canon Video... • Answered on Jan 16, 2023
Need help understanding a transfer from the Canon MV830i camcorder to Macbook
  1. To transfer video footage from your Canon MV830i camcorder to your Macbook, you will need a FireWire cable and a FireWire USB adapter. This cable connects the camcorder to your computer, and the adapter allows the FireWire connection to be recognized by your Macbook. You can find this cable and adapter on Amazon or other electronics retailers.
  2. To transfer the footage to your computer, you can use the built-in iMovie software on your Macbook. This software lets you capture the footage from your camcorder and import it into the program for editing.
  3. You can reuse the tapes by recording the footage you have already captured. Make sure you have transferred the footage to your computer before recording it.
  4. Some other advice:
  • Make sure your camcorder is in VCR or VTR mode before connecting it to your computer.
  • Test the connection and transfer process before filming important footage.
  • Check the manual of the camcorder for detailed instructions on how to transfer footage.
  • Be patient; transferring footage from a camcorder to a computer can take some time.
Remember that transferring footage from a camcorder to a computer can be a bit complicated, but with some patience and practice, you'll get the hang of it. Remember always to consult the manual of the camcorder for detailed instructions and always keep your computer and software updated.
1/14/2023 1:36:51 AM • Canon Video... • Answered on Jan 14, 2023
I want to connect a Canon ZR 800 using firewire to my MacBook Pro.
To connect your Canon ZR 800 camcorder to your MacBook Pro using a Firewire connection, you will need a Firewire cable and a Firewire port on your computer. Here are the steps you can follow to connect your camcorder to your MacBook Pro:
  1. Locate the Firewire port on your MacBook Pro. It is usually located on the side or back of the computer and is marked with a symbol that looks like a small lightning bolt.
  2. Connect one end of the Firewire cable to the Firewire port on your MacBook Pro.
  3. Locate the Firewire port on your Canon ZR 800 camcorder. It is usually located on the side or back of the camcorder and is marked with a symbol that looks like a small lightning bolt.
  4. Connect the other end of the Firewire cable to the Firewire port on your camcorder.
  5. Turn on your camcorder and set it to playback mode.
  6. Open the video editing software on your MacBook Pro and choose the option to import video from a Firewire device.
  7. Follow the prompts in the software to import the video from your camcorder.
I hope this helps! If you have any further questions, don't hesitate to ask.
1/7/2023 11:13:11 PM • Canon Video... • Answered on Jan 07, 2023
Canon vixia recording with color problems
If you are experiencing color problems while recording with your Canon Vixia camcorder, there are a few steps you can try to troubleshoot the issue:
  1. Make sure that the camcorder is properly focused. If the focus is off, the colors may appear distorted or blurry.
  2. Check the lighting conditions. If the lighting is too dim or too bright, the colors may appear distorted or washed out.
  3. Check the white balance settings on your camcorder. If the white balance is not set correctly, the colors in the video may appear inaccurate.
  4. Clean the camcorder's lens to remove any dirt or smudges that may be affecting the image quality.
  5. If you are using an external device, such as a monitor or TV, to view the video, make sure that it is properly calibrated.
If you have tried these steps and are still experiencing color problems with your camcorder, you may want to try contacting Canon customer service for further assistance. They will be able to provide you with more specific troubleshooting steps based on your particular camcorder and the issues you are experiencing.
1/7/2023 11:08:19 PM • Canon Video... • Answered on Jan 07, 2023
Canon es55 video camera. Everytime I put a tape in, it ejects it. If I take the tape out, and close the door,it will will automatically close and stay closed
Hi, Please first make sure that there is nothing within the video camera that was accidentally lodged into the space where the tape would fit. Also, please double check that you're orienting the video tape properly when inserting it into the video camera. I would also test different tapes to see if the issue is consistent. Also, you might have to rewind each tape because I think if the tape is at it's end, then it automatically leads to the tape being spit out. Thank you.
10/11/2022 12:29:06 AM • Canon Video... • Answered on Oct 11, 2022
Canon Elura 50 Mini DV Digital Camcorder Logo
Popular Tags
24 questions posted
Top Canon Video Cameras Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Elura Canon
  • Elura Canon
Most Popular Question
condensation detected
  • Video Cameras
