20 Most Recent Canon Elura 60 Mini DV Digital Camcorder Questions & Answers
2answers
I HAVE THE SAME HELL PROBLEM WITH THIS ELURA60...
fixya site is not canon site so find the correct web page for canon and vent your anger in their customer section and it doesn't matter if the unit is imported or not , the service agent for canon have to fix it if it is still under warranty
7/1/2017 9:08:49 AM • Canon Elura 60... • Answered on Jul 01, 2017
0answers
2answers
Canon Elura 60 zooms by itself
Listen, I know it's a couple of years after this post but, try this: Remove cassette, push to close, close camera as if to use it, hold firmly in left hand, open hand slap it with your right hand once or twice, (I'm not joking) it worked the two times I had this problem. Problems with the zoom? Almost same process, push firmly on zoom button (to un-zoom) try doing this as your tapping it. These are last ditch efforts on an aging camera, it really has been a good one. I've put this poor thing through years of abuse, and it's held up pretty well. Good luck, Jeff S.
12/18/2013 11:22:16 PM • Canon Elura 60... • Answered on Dec 18, 2013
When i play the vtr
This is most likely a defective zoom rocker switch assembly and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
8/23/2013 5:40:49 PM • Canon Elura 60... • Answered on Aug 23, 2013
My canon elura 60 digital
Sometimes a smack around the edge of the lens will work. If it doesn't, then it might be a motor issue and will need to be taken apart.
8/23/2013 5:33:20 PM • Canon Elura 60... • Answered on Aug 23, 2013
13answers
Elura 60 Zoom Problem
Guys, so weird but on another site it offered this suggestion: banged the base of your camera against something hard and it will become unstuck. So bang the base of your camera against something hard and it will work again, at least it works like it did but not sure for how long. Good luck. I can't believe that worked. Give it a try. I didnt hit it too hard either.
9/19/2012 7:01:57 PM • Canon Elura 60... • Answered on Sep 19, 2012
2answers
Disabling the Auto-Off Power Function on Canon Elura Camcorder in Record Mode
Take the tape out. The Camera should stay on.
3/8/2012 2:40:31 PM • Canon Elura 60... • Answered on Mar 08, 2012
When I play back a miniDV cassette in my Canon
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
9/14/2011 9:11:03 PM • Canon Elura 60... • Answered on Sep 14, 2011
Won't except tape...door will not
This is usually caused by a defective component in the tape detection circuitry and will require disassembling the camera to repair. This can usually be done fairly inexpensively. However, it's not really a user serviceable problem and will need to be repaired qualified service technician.
9/7/2011 11:20:38 PM • Canon Elura 60... • Answered on Sep 07, 2011
My canon elura 60 when
The zoom assembly will need to be replaced. This repair should be done by an experienced technician. Unfortunately, there is no easy fix that you can do yourself.
Hope this helps you.
www.austintelstarservices.com
7/23/2011 3:25:44 AM • Canon Elura 60... • Answered on Jul 23, 2011
0answers
What do I need to
A firewire cable is the only way.
USB can only download stills.
4/15/2011 12:54:58 PM • Canon Elura 60... • Answered on Apr 15, 2011
CONDENSATION DETECTED
It's because the camera has been taken from a heated room to a cold external.
This is normal and is to protect the camera and tape.
You have to wait until the camera acclimatizes, about an hour or so.
3/18/2011 5:14:00 AM • Canon Elura 60... • Answered on Mar 18, 2011
I put in my mini
Tape mechanism problems can be quite complicated. This will require disassembling the camera to repair the tape mechanism and can be done fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
3/7/2011 4:52:18 PM • Canon Elura 60... • Answered on Mar 07, 2011
My canon elura 60 mini
2/7/2011 3:56:15 PM • Canon Elura 60... • Answered on Feb 07, 2011
5answers
Canona Elura 60 problem...
What a hunk of junk. Not a month after the warranty period expired, my Elura 60 would zoom out without warning and refused to stay zoomed in. I paid Canon to fix that problem.
Now, I'm on vacation (in the Carribean for more than 24 hours) and the unit wouldn't accept a tape. Every time I tried to load a tape, it would beep five times and then kick the tape out. So I tried taking all of the batteries and media out. That didn't work.
Next, I tried the drop method. I figured the unit is broken and I'm not going to pay again to get it fixed, so dropping it couldn't break it anymore than it already is. I let the unit fall onto the throw rug in the bathroom. In then tried to install a tape. Waddyaknow! It worked.
I can only reiterate again two things: dropping the camera from about 6" onto a carpeted surface over a tile floor seemed to clear up my "remove the cassette" problem, and the Elura 60 is a temperamental hunk of junk (although the recordings and playback are pretty good, when you can actually get a tape into the unit).
12/23/2010 3:34:38 PM • Canon Elura 60... • Answered on Dec 23, 2010
Canon Elura 60 Mini DV Digital Camcorder Logo
55 questions posted
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Elura Canon
  • Elura Canon
Most Popular Question
won 39 t except tape door will not
  • Video Cameras
