20 Most Recent Canon ZR300 Mini DV Digital Camcorder Questions & Answers
Old or worn Audio Tape Head needs replacing, Head Cleaning tapes are not the best for these, they can only be used so many times and they do rub tape carbon into the tape head, best thing to do is get an ear bud cleaner -"Cotton Buds" - and dip it into metho and give the tape head a light rub with it and ear bud, should do it...if still has issue then the tape audio head is had it, but rarely do they breakdown.
Canon ZR300 Mini... • Answered on Apr 26, 2017
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Canon ZR300 Mini... • Answered on Jun 05, 2015
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
Canon ZR300 Mini... • Answered on Apr 01, 2014
if you still need it, i'd be happy to offer you mine. almost brand new (canon SD memory card sdc-8m).
Canon ZR300 Mini... • Answered on Oct 19, 2012
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair cost low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Canon ZR300 Mini... • Answered on Sep 23, 2011
Canon ZR300 Mini... • Answered on Sep 06, 2011
Any burning software will work what ever brand you chose, I preferre Nero, but windows Vista and 7 have software already built in to recognise most all cameras. So you don't really need anything els unless you chose. Wasn't there software included in the camera? there shouls have been a CD or DVD that came with the camera. You can also check the Canon website for more info and software
Canon ZR300 Mini... • Answered on Jun 28, 2011
I know this is going to sound strange. I had the same issue with my ZR300. When you insert a tape and close the mechinism you hear the tape whirl then it pops open and chimes. I found a solution online and thought it was to good to be true. It said to hold the camcorder in your left hand with the right side up (the opposite side of the fold out viewer). You then hit the camcorder , not real hard like slapping something. Open the door and insert the tape and WHAM! It loaded fine. Eight people had tried it according to the review and all eight people had success. I was skeptical but it works! Don't hit it so hard you break it. I did mine twice before it worked but it works everytime now. Trust me just try it and it will work.
Canon ZR300 Mini... • Answered on May 30, 2011
Greetings Edward - The message means that your recording or playing directly to/from a SD card and not a DV tape and the file system on that card is damaged and the video cannot be stored on or played back from it.
It might help if you remove the SD card and reinsert but if that doesn't work you would either have to get a new SD card, or if there is data on the card that you need to retrieve, try to repair the card via a PC and some software. The software on the web HERE does a good job of recovery (I have no affiliation).
Good Luck,
Mikeywaf
Canon ZR300 Mini... • Answered on May 29, 2011
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Canon ZR300 Mini... • Answered on May 12, 2011
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
Canon ZR300 Mini... • Answered on Feb 18, 2011
Tape mechanism problems can be quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
Canon ZR300 Mini... • Answered on Dec 25, 2010
Canon ZR300 Mini DV Digital Camcorder Logo
57 questions posted
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
View Most Popular
ZR Canon
  • ZR Canon
Most Popular Question
need sdc 8m 8mb sd memory card canob zr
  • Video Cameras
