20 Most Recent Nordic Track Commercial 1750 Treadmill Incline Motor Questions & Answers
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
Nordic Track... | Answered on May 25, 2014
cleal the contacts relais, and replace if necessary. Of course your LUBE the gear and shaft too.Test the elevation motor for problem bearing for repair.
sincerely. God bless you
Nordic Track... | Answered on Jun 23, 2020
https://www.audiusa.com/content/dam/audiusa/brochures/2019/2019_Audi_Q7_QSG.pdf
Nordic Track... | Answered on Apr 10, 2020
https://www.manualslib.com/manual/583110/Nordictrack-Commerical-2450-Treadmill.html?page=27
Quoting from manual above (may be similar model if not the same.)
7. Turn on or turn off the display demo mode.
The console features a display demo mode,
designed to be used if the treadmill is displayed
in a store. While the demo mode is turned on, the
console will function normally when you plug in
the power cord, press the power switch into the
reset position, and insert the key into the console.
However, when you remove the key, the screen will
show a demo presentation.
To turn on or turn off the display demo mode, first
touch the Demo Mode button. Next, touch the On
checkbox or the Off checkbox.
Nordic Track... | Answered on Mar 06, 2020
Hello
The servo motor which changes the resistance (under the plastic covers) is winding the cable in the wrong direction. Release tension on the cable by pulling the magnets away from the fly wheel and flip the cable off the the servo motor pulley, this will allow the cable to be pulled in the correct direction.
Nordic Track... | Answered on May 19, 2019
Controller . I aman authourised repairer for the brand in Australia .
Nordic Track... | Answered on Apr 28, 2019
Try resetting the router.
Nordic Track... | Answered on Apr 25, 2019
Try spraying silicone spray under the belt. It worked on mine. You can buy spray cans from a Hardware or Bunnings etc.
Nordic Track... | Answered on Apr 07, 2019
It would appear via one video and someone else's post that it is at the front of the machine, directly above the crossbar that contacts the floor.
Nordic Track... | Answered on Mar 04, 2019
Nordic Track Commercial 1750 Treadmill Incline Motor Logo
1 questions posted
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Nordic Track Exercise & Fitness
Most Popular Question
wrong fix incline nordictrack commercial
  • Exercise & Fitness
