20 Most Recent
Nordic Track Nordictrack Track E 3700 Treadmill Rear Roller For Model Number: Questions & Answers
Nordictrack 3700 makes a knocking sound when I run on it
Hello.
Knocking noises more than likely come from the rear roller, there could be a small chance it's coming from the motor it's self though.
Have some walk on the machine and make the noise while you locate which end of the treadmills coming from.
If it is the rear roller the bearings will need to be replaced, this can be done by removing the rear roller and taking it down to any bearing shop and have them locate the bearing numbers. Ask them for advise on removing them as well.
If the noise is coming from the front of the treadmill then have a look at the fly wheel coming off the motor, locate grub screws and tighten.
GymWorld.net.au
NordicTrack treadmill EXP 1000
Please note that these instructions don't apply to all models of treadmills. Many recent models, including all models with touchscreen consoles, do not have the capability for the user to calibrate the speed.
Speed calibration is a process that is used to correct imbalances in the machine's operating speed.
Please note that this procedure involves pushing the machine to its maximum speed very quickly. Do NOT stand on the treadmill while performing this procedure.
First, you need to enter calibration mode on the console. To do this, press and hold the STOP and SPEED INCREASE buttons (this will be either an up arrow or a + (plus) symbol). While holding these buttons, insert the safety key onto the console. This will cause the machine to go into calibration mode. After this has occurred, you may let go of the buttons and the safety key.
Next, press the stop button once. This will enter advance the screen to the next feature of calibration mode. As said previously, do not stand on the treadmill while performing this procedure. Press and hold the speed increase button. Watch the console. You will see a number on the display that will increase as you hold the speed increase button. Continue to hold the speed increase button until the number changes to "85." This will take the treadmill to its maximum speed, which will also be displayed on the console. Please note that the example below only demonstrates the console displaying "85", not the treadmill's operating speed.
Elite 7700 treadmill. Why is there no power to console?
If the electrical outlets work and are fine unplug the treadmill and then check the power cord for any damage. Replace the power cord if it's damaged. If the power cord is fine and looks fine then check the circuit breaker switch on the treadmill and reset the circuit breaker switch if it's tripped.
