20 Most Recent Magic Chef 31203 Gas Kitchen Range Questions & Answers
Clock assembly light fading. Did self cleaning oven and it fixed it. Do I still need a new assembly?
The self cleaning heats the oven to a temperature higher than standard operating temp for the panels to burn the dirt off, this also heats up the rest of the oven, Your clock module will have dry solder joints, these can be fixed and if you are handy with a soldering iron it is a reasonably simple job. Just be sure to disconnect the power before removing the clock module.
3/11/2012 12:39:11 PM • Magic Chef 31203... • Answered on Mar 11, 2012
How do you light the pilot
Hi:You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time. Hopefully one of other experts will be able to provide you with a real solution. Thank you for using FixYa.
2/13/2012 8:58:04 PM • Magic Chef 31203... • Answered on Feb 13, 2012
Have an older model 31203...installing
Well problem seems in the Thermocouple, it is the stick looking thing that is in the pilot lights flame. You can replace it for about $5 to $6 and they are available at places like Home Depot or Lowe's.
post comments for more help or information......
Good Luck!!
Thanks
12/14/2009 10:09:11 PM • Magic Chef 31203... • Answered on Dec 14, 2009
The pilot light is burning but the oven will not
igniter/glow plug assembly may not be sensing the pilot.may need to replace.
10/16/2009 6:20:02 AM • Magic Chef 31203... • Answered on Oct 16, 2009
OVEN WILL NOT (GAS) LITE
With the assumption you have a gas range with electric ignition and is fully powered (plugged in); the possible problem may be the "Electric ignitor/Glow bar".
When turning on the oven, do you see a redish (good) or yellowish (not good; replace) glow emitting from the very bottom or the oven/broil area?
There are typically 2 types of electric glow bar ignitors; Round and Square. Ignitors are actually fairly easy to replace, removing 2 mounting screws and cutting/splicing 2 seperate wires together. Is your ignitor "round" (circular - like size of finger ) or "square" (rectangular - like snickers candy bar)
If your ignitor is not coming on at all; this can be a couple things;
Defective Ignitor - Gone completely Bad - Out (Assuming your have full power 110v to ignitor)
Defective Gas Valve - Assist in passing 110V to Ignitor
Defective Control Board / Thermostat: Assist in passing 110V to Ignitor
FYI - As a safety measure, the ignitor needs to "come on and appear solid red" to properly pass power to gas valve; thus opening and allowing gas to pass through the burners and combust.
1/27/2009 12:08:57 PM • Magic Chef 31203... • Answered on Jan 27, 2009
Oven not working (lighting) on magic chef stove top/oven
look at the burners in the oven,they usually go bad where they hook to the unit,it will look like a peice is missing.if this is not the case, a wire is loose in your breaker and you're running on 110 instead of 220
11/14/2008 11:27:27 PM • Magic Chef 31203... • Answered on Nov 14, 2008
Magic chef oven
look at the burners in your oven,they usually go bad where they plug in.it will look like a peice is missing.if this is not the case one of the wires is loose on you breaker and you're running on 110
11/14/2008 4:04:32 PM • Magic Chef 31203... • Answered on Nov 14, 2008
Lighting pilot light on Magic Chef oven: CGS3760ADC
since it is piotless how did you light burner pilots? The oven is piotless and does not have a free standing pilot. here is a link to manual copy and paste page 18 deals with oven. piotless
1/9/2024 1:25:48 AM • Magic Chef... • Answered on Jan 09, 2024
Where does the power come from on my gas magic chef oven
If you click on your name it takes you to posting history. Or you can click upper right and click 'My Home'. It was answered. https://www.fixya.com/users/james-dean-88131 ..
11/7/2022 6:03:08 PM • Magic Chef... • Answered on Nov 07, 2022
I have a Magic Chef oven that won't get to temperature?
Question edited for clarity and create a few sentences. A gas certified technician needs to fit a new thermostat. They can source the part, fit it and check for safety.
11/6/2022 2:27:00 AM • Magic Chef... • Answered on Nov 06, 2022
2answers
I'm looking for a manual for Magic Chef gas range 8114P732-60. I want to know how to use the self clean feature.
This number - 8114P734-60 - is a part number (possibly for the tag it is on). It is not a model. Note: the part number does is not listed in any current parts lookups. Could be a non functioning number or too old to be listed.
2/27/2021 11:19:23 PM • Magic Chef... • Answered on Feb 27, 2021
2answers
Changing a magic chef mod# 30011 PAW. From Lp to Ng
get orfices from your gas providers
1/12/2021 5:07:54 AM • Magic Chef... • Answered on Jan 12, 2021
2answers
How do I turn off the pilot light in my Magic Chef 31000paw oven? I think when it stays on it is wasting gas.
I don't know. While half a century ago it was common that pilot lights would be permanently lit to provide instant lighting of oven and hobs, because they did consume a significant amount of gas they fell out of favour and spark ignition became reliable. Amid a number of related and unrelated accidents the gas oven began to be seen as potentially dangerous and so they were fitted with a couple of safety devices so for a considerable time the pilot light has to be relit every time the oven is used and the pilot light will be switched off when the oven burners are turned off. Thinking back a long time, the pilots of our old cooker could be turned off using a screwdriver to turn a central service valve hidden under the hob spill tray.
6/27/2020 12:41:46 AM • Magic Chef... • Answered on Jun 27, 2020
I have a magic chef rev range and I am looking for 3 burner inserts #7214po15-60 or something to replace it . It seems to be no longer available
try manufacturer possible replacement number --appliance repair shop -online search
6/11/2019 3:06:53 PM • Magic Chef... • Answered on Jun 11, 2019
I need a conversion kit # to change from natural gas to propane for a magic chef mdl31213wav
Sorry we do not have that kind of information, your local LP gas supplier can get what you need call them.
6/19/2018 8:35:32 PM • Magic Chef... • Answered on Jun 19, 2018
Electric spark will not work, burners will not light
The spark electrode sends a spark to ignite the gas in the burner assembly. If the spark electrode is defective or worn out, it might not produce a spark, or the spark might be too weak to ignite the gas. As a result, the spark electrode will make a clicking sound when the burner is turned on, but the burner won't light. If the spark electrode is defective, replace it. I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
3/25/2018 5:01:51 PM • Magic Chef... • Answered on Mar 25, 2018
Magic Chef 31203 Gas Kitchen Range Logo
18 questions posted
Top Magic Chef Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Kitchen Ranges
Most Popular Question
clock assembly light fading did self
  • Kitchen Ranges
