20 Most Recent Yakima Rack and Roll Trailer - 66" 8008106 Questions & Answers
Hey Bill, NADA does not list a 2605 for 2009..
is this an outboard or stern drive..
2009: 2301 WA STRIPER 24' STERN FG 1 220 4450 8'6" Gasoline 2301 WA STRIPER(**) 24' OUTBD FG 1 200 3850 8'6" Gasoline 2601 CC STRIPER(**) 26' OUTBD FG 2 150 4250 8'6" Gasoline 2601 WA STRIPER 26' STERN FG 1 270 5150 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 2 150 4550 8'6" Gasoline 2601 WA STRIPER(**) 26' OUTBD FG 1 225 4550 8'6" Gasoline 2009 Seaswirl Boats Prices Values
Boating | Answered on Apr 21, 2020
GOOGLE IT WITH THE MAKE STATED FIRST
This one?
https://www.walmart.com/ip/Electronics-Built-In-Bluetooth-Marine-Antenna-Cone-USB-DIN-Speakers-Stereo-LCD-Range-Two-Port-WCP365BT-Single-Long-inch-Dual-6-5/658806335
RT is normally reserved for transmitting, this is a receiver. Or is it linked to a two way transceiver and automatically cuts out music for telegraphy transmissions coming in?
I can't find the manual for it. The reviews at the lower part of the page suggest it is a bargain basement unit. I have a Jenson :>)
Boating | Answered on Apr 11, 2020
the #1 failures all all things with batteries are.....
1: battery bad.
2: battery bad.
repeat
not only that, but a bad battery makes the charger lie..
do you understand why, that is easy an old battery may still work some, and have 1/10 capacity left, but the charger does not know that, so lies to you. (only load testing proves any of that)
Boating | Answered on Mar 27, 2020
My E4RCCS 1988 outboard has a diagram at the fuel inlet that says 100:1 fuel mixture
Boating | Answered on Feb 29, 2020
Hello. You have two springs in carburetor and one in Magneto roto. No spark I pick the Magneto. For complete brake down illustration I suggest Sears parts on the web. Good luck & happy fishing.
Boating | Answered on Jan 22, 2020
NONE OUTSIDE OF THE BOAT ONLY GAS FILLER THERE
Boating | Answered on Jan 09, 2020
This is probably the best route to take. Get the Service Manual if you intend to do your own servicing.
https://www.marineengine.com/manuals/seloc/online-manuals/johnson-evinrude-outboard-manual-online.html
This shows wiring thumbnails but don't lead the the wiring diagram
https://www.google.com/search?q=evinrude+e25telcnb+solenoid+wiring+diagram
Boating | Answered on Jan 08, 2020
Tightening clutch on capstan should fix the problrm
Boating | Answered on Jan 05, 2020
Brand new... thats why they have warranties
Boating | Answered on Dec 15, 2019
4600 lbs.
IF IT DROPPED PERHAPS 1/2 INCH THE SHIFT ROD NEEDS DISCONNECTED .
Boating | Answered on Nov 30, 2019
GO SEE YOUR LOCAL DEALER FOR ASSISTANCE
Boating | Answered on Nov 24, 2019
MEASURE IT AND GET SMARTER FOR YOURSELF
Boating | Answered on Nov 23, 2019
I think there is a nut holding the prop to the shaft and there might be a shear pin going through the prop and shaft. Remove those to get the prop off. It may have been on so long, there might be rust and other junk holding it on. Spray with penetrating oil and let sit to loosen the rust.
Boating | Answered on Oct 31, 2019
Yakima Rack and Roll Trailer - 66" 8008106 Logo
1 questions posted
Top Yakima Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Yakima Boating Expert? Answer questions, earn points and help others
View Most Popular
Yakima Boating
  • Yakima Boating
Most Popular Question
find serial number rack roll trailer
  • Boating
