20 Most Recent
Zalman Tech (CNPS7700CU) CPU Fan Questions & Answers
Cpu fan
There are usually more than one place to plug in a CPU fan. Only one of them is actually for the CPU fan, and monitored by the system BIOS. Make sure your fan is plugged into the right connector.
I have installed a Zalman
Could be. The PWM fan's operation will vary depending on the motherboard's BIOS settings.Please check your motherboard's BIOS settings.
Good day
No. The ZM-WB5 is only compatible with Intel’s LGA775 and socket 478, as well as a few AMD processors. The Core i7's have LGA 1366 sockets.
Cpu fan not running fast enough
This will depend on the motherboard you are using.
however, you need to make sure that the CPU fan lead is plugged into the correct plug on the motherboard... for example, I have an Intel 975xbx motherboard and it has 4 fan plugs, but only one of those is for the CPU. The others are for front/rear/top fans. If the CPU fan is plugged into one of the secondary ports, the CPU fan wont speed up correctly.
Also, some BIOS settings in the motherboard allow you to enable or disable automatic fan speed adjustment, and also set the temperature points.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
