20 Most Recent Magic Chef CGC2430 Gas Cooktop Questions & Answers
Suggest that the new igniter is defective.
The bath tub concept of early failures is the most likely explanation this recurring failure,
The prior failures relate to the late in component life the far end of the bath tub curve.
Hope this helps?
The Bathtub Curve and Product Failure BehaviorPart One The Bathtub Curve...
Magic Chef... | Answered on Jun 29, 2017
Have you had a spillover? Lift the burner cap the round thing on top of the burner then pull out the burner you might see a small hexagonal brass thing with a hole in the centre if it's blocked clean it with some acetone/ nail polish remover.
Magic Chef... | Answered on Jun 28, 2014
one of the switches may be bad.
Magic Chef... | Answered on Nov 23, 2010
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Magic Chef... | Answered on Aug 21, 2010
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Magic Chef... | Answered on Aug 19, 2010
Hi nschulman,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Magic Chef... | Answered on Aug 03, 2011
TRY SEARSPARTSDIRECT.COM YOU HAVE TO LOOK IT UP BY THE STOVE MODEL NUMBER
Magic Chef... | Answered on Feb 22, 2011
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote to give details about why your cooktop will not spark to light the burners..
heatman101
Magic Chef... | Answered on Sep 08, 2010
The model and serial will be on a sticker on the under side of the cooktop somewhere...
heatman101
Magic Chef... | Answered on Aug 05, 2010
Hi, normally what causes the igniter to keep clicking is spilling water or something down into the knob area. The water is causing a short circuit in the switch which is mounted on each burner valve shaft. If unplugging the range for several days to allow drying doesn't fix the problem, then one of the switches will need to be replaced.
Magic Chef... | Answered on Jan 28, 2010
defective touch pad or clock, Replace touch pad or clock (ERC). Touch pad is a more common problem.
you need a new :
"clock board"
Magic Chef... | Answered on Sep 12, 2009
Magic Chef CGC2430 Gas Cooktop Logo
Popular Tags
5 questions posted
Top Magic Chef Cooktops Experts
jdthefixer
ray gallant
Tom Chichester
Are you a Magic Chef Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Magic Chef Cooktops
  • Magic Chef Cooktops
Most Popular Question
am trying fix mother in laws magic chef
  • Cooktops
