20 Most Recent Acer Aspire One D255 Laptop Questions & Answers
The boot disc is one that might be supplied with a computer or one you made yourself that could be capable of rescuing the system if any serious software bugs or glitches prevent the system booting up naturally. The boot disc is a sort of kick-starter for when the electric start is broken.
Years ago before the advent of the hard drive the boot disc was what was loaded to make the machine work, before any other programmes could be used.
Acer Aspire One... | Answered on Mar 01, 2015
Run check disk asap
Acer Aspire One... | Answered on May 01, 2014
That usually means that your HDD (hard disk drive) is dead and its no longer readable. By start up pres F2 normaly thats the button normaly that will lead you to the BIOS go on overview and see if your HDD is still detected by BIOS. You can also try to see how bed things are by inserting a rescue disk on your CD/DVD drive press F12 when you do that and try to diagnose the problem. You can also try to reinstall your OS(operation system) sometimes that also helps but not in many cases. I Hope that help you a bit.
Acer Aspire One... | Answered on Feb 20, 2014
to add a second monitor first make sure your laptop has a VGA connection (newer laptops have replaced these with HDMI or DVI, if you have these connections then use them)
now plug the VGA into the port, if the laptop is setup right it will pick it up automatically. if not you will have to do it yourself
so first right click on the desktop and go to screen resolution
in this new window there will be an option to either duplicate or extend with the choice of which monitor to use.
set it up how and as you wish if you are going for more than one screen it is recommended you buy a desktop with a graphics cards that supports up to 3 monitors
Acer Aspire One... | Answered on Jan 02, 2014
right click then propertis or persoanalise then display the chouse what you wont in a display
There should be a button on the front of the computer. you slide it on and off.
Acer Aspire One... | Answered on Jul 27, 2012
Are asking how you change the font in your software? If so, I assume you have Microsoft Word since thats what this laptop normally comes with. If you are working in Microsolf Office Word click on "Home" at the top of the page and you will see a section at the top of your page that says "font" about that you will have severals options to change the font. If you are working in Microsolf Word move your curser to "format" a dropdown window will appear the first idem on the window is "font" click on "font" and you wil be taken to a screen where you will have several options for changing your font. I hope this helps.
Acer Aspire One... | Answered on Jun 28, 2012
call (contact) Acer.com
only they can cure that legally,l
Acer Computers &... | Answered on Jan 11, 2020
whats the question?
Acer Computers &... | Answered on Jan 06, 2020
well those notebooks stink, they are cheap and for cheap you get only this tiny space. and fills up fast with apps and data
25GB is way way too small.
Acer Computers &... | Answered on Jan 05, 2020
DVD-RW
It is the re-recordable version of the DVD-R. To use this type of media you will need to buy a DVD-RW recorder. The DVD-RW recorders usually record DVD-R, CD-R and CD-RW media, too. Similarly to what happens to DVD-R, DVD-RW disks can be played in newer commercial DVD players without any problems. Older commercial devices cannot recognize the media, refusing to play the disk. To play a DVD-RW disk, commercial players need the disk to be finished. After finishing the disk, you can only record new data in it by reformatting it, which makes you lose all the recorded data.
DVD+RW
It is the re-recordable version of the DVD+R and everything that was said about the DVD+R is valid for the DVD+RW. Only the newest DVD players play movies recorded in disks using this format. There are recorders on the market that can record both DVD-RW disks and DVD+RW ones. These recorders are called DVD?±RW. Similarly to the DVD-RW, the disk needs to be finished to be played in commercial DVD players, and to record new data in the disk after having finished it requires reformatting it, which makes all the data in it to be erased. DVD+RW recorders are usually capable of reading DVD-RW disks (but not of recording them) and vice-versa.
There you are.
Acer Computers &... | Answered on Jan 03, 2020
hi,
pls check that the video format supports for ur window media player,
may be sound decoder not installed in ur laptop. (as there are many sound formats, window media player support some of those).
Solutions:
Pls install VLC player, or Gom player, OR Nero 10. and play DVD, XVID, or CD.
follow links that u can download.
VLC Player--- http://download.cnet.com/VLC-Media-Player/3000-13632_4-10267151.html
Gom Player-- http://download.cnet.com/GOM-Media-Player/3000-13632_4-10551786.html
Note: If you r not getting sound, that not problem with Graphics card.
Hope this message will helpful for you...........
Thanks
Sudhakar. R
Email ID- [email protected]
Acer Computers &... | Answered on Dec 27, 2019
Control panel, uninstall android prog.
Access android web site and download their latest update for your unit.
Acer Computers &... | Answered on Dec 25, 2019
Hello,make sure the video is encoded in one of the following formats:
QuickTime Movie (mov)
Windows Media Video (wmv)
AVI Video (avi)
MPEG Video (mpg, mpeg)
Windows Media Video (asf)
MPEG-4 Video (mp4, mpeg4)
Mobile Video (3gpp, 3gp, 3g2)
Matroska Format (mkv)
Flash Player Video (flv)
DVD Video (vob)
Ogg Format (ogm)
Nullsoft Video (nsv)
Second you need to add the Video application to your account. You can find this application here, you can click this link after you log in.Once you have this application, follow these steps to upload a video:
1-Go to your profile.
2-Select the Wall tab.
3-Click 'Video' inside the Publisher box.
4-Select which type of video you'd like to make.
5-Follow the on screen directions for your particular upload type.
When you're done, click "Post" to generate a story about your video and store the video permanently in My Videos
I hope i helped
My condolences for your loss
Acer Computers &... | Answered on Dec 10, 2019
Press and hold F10 when booting for the recovery partition on the hard drive and follow the instructions.
Acer Computers &... | Answered on Dec 09, 2019
Acer Aspire One D255 Laptop Logo
13 questions posted
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
View Most Popular
  • Acer Computers & Internet
Most Popular Question
boot disk
  • Computers & Internet
