20 Most Recent Citizen IDP562-RSL2-120 Matrix Printer Questions & Answers
2answers
I need a replacement for
Any POS printer should work.
Look here at Epson http://pos.epson.com/posindex
2/15/2011 6:27:33 PM • Citizen... • Answered on Feb 15, 2011
Verifone Trans 330 says "Printing" after the transaction but printer does not print.
First off, verify that the printer is powered on. This may be a basic thing, but many, many people don't realize that the printer either was turned off accidentally, or the power plug came loose.
Check that the cable connecting the terminal to the printer is securely connected at both ends. If this doesn't resolve the issue, pull the and check the ends of the plug on the cord at each end to make sure that the pins inside are not bent.
If you are running a Verifone printer, you can run a print test to make sure the printer is working by turning the printer's power off, and then while pressing and holding the paper feed button (green button on top) turning the power back on. The printer will start printing test characters (you can release the button when it starts printing). To stop the test, just power the printer off again and then back on.
If the above suggestions don't fix the problem and it was working fine at an earlier date - you most likely have a bad printer. You can also contact your processor's Help Desk and have them check to make sure the settings on the terminal and/or printer didn't changed somehow.
Hope that helped!
9/5/2009 5:53:02 PM • Citizen... • Answered on Sep 05, 2009
0answers
IDP / 3421
Be the first to answer 2/26/2014 3:11:16 AM • Citizen IDP... • Posted on Feb 26, 2014Be the first to answer
Ct-500 calculator display became black how to make it normal
have you replace battery?
5/29/2022 2:37:21 PM • Citizen Office... • Answered on May 29, 2022
Printer is in an error state
You are a printer user, you have possibly faced a Printer is in an Error State problem. If you come across one, an error note will pop up on your PC telling you Printer is in an Error State. Your printer cannot get to run at this time. If you want to find some helpful answers to this problem. You can give the methods below a try. This blog can help you to fix your Printer is in an Error State issue. Easy steps to solve Printer Is In An Error State: 1. Check the attachment and Reboot your devices. 2. Update or reinstall the printer driver. 3. Contact printer Service Provider. 4. Full BLOG with SOLUTION- Printer Is In An Error State The Printer Is In An Error State difficulty while trying to get a print from your printer on Windows? A Printer is in an Error State is a simple problem that is faced by all brands of printers. If you have updated your system from a previous version to the latest Windows, you might be facing this problem a lot more. In this step-by-step tutorial, you will learn how to fix the Printer is in an Error State. If the Printer Is In An Error State is not resolved, this might mean there's waste within the printer's inside. Check this Blog for a full solution or Call customer services. printer-support-3-undefined-undefined-2_9.jpg
5/28/2020 8:51:17 AM • Citizen Office... • Answered on May 28, 2020
Have a citizen cy printer but just started running slow can these be serviced or what can it be
make sure to reduce the resolution value to make it run faster.
3/13/2016 1:47:48 AM • Citizen Office... • Answered on Mar 13, 2016
My citizen ct 500 Calculator not show numbers clearly.
replace the battery/s
11/23/2015 7:50:49 AM • Citizen Office... • Answered on Nov 23, 2015
Need help
Before throwing away you unfunctional calculator change the battery. Some calculators act weird when low in battery.If you decide to throw away you non functional device, please remember to remove the batteries and use ecologically safe disposing procedure, mayba some recirculation center.
7/31/2015 3:33:50 PM • Citizen Office... • Answered on Jul 31, 2015
CAN I REPLACE THE BATTERY? IT IS A GP SILVA-CELL 189
Yes! These 2 numbers are same type of cell. Lr1130p Lr54
3/6/2015 11:29:00 AM • Citizen Office... • Answered on Mar 06, 2015
4 questions posted
Top Citizen Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
IDP Citizen
  • IDP Citizen
Most Popular Question
need replacement
  • Office Equipment & Supplies
