20 Most Recent Lenoxx Electronics CD-88 Personal CD Player Questions & Answers
My model CD-88 programmable compact disc player player will go around but no music comes from it. It is one that you can use in your car tape player as it has an adapter. What is wrong with it ? Thank you. Estella Huffman [email protected]
Lenoxx... | Answered on Oct 29, 2018
Hello
The sled motor of your player is not working. This is the motor that spins the disc inside as soon as it has been loaded. But to spin disc, the disc must be loaded properly into the loading mechanism. Just check the loading belt that attached with loading motor and loading gear set for any loose, which may cause improper disc loading. Replace it first. If it does not help you, check the voltage at the seled motor terminals. There must be a voltage [4.5VDC approx:]. If the voltage is there and still the sled motor does nor work, replace it. If voltage is not there, the fault is with the loading IC which is soldered to the main board of the device. OK>
Lenoxx... | Answered on Jan 05, 2012
if the problem came from the factory it may be unavailable for the model ...but also can be just a software issue ..and updating the firmware can fix it ..Remember that updating firmware is a 2 way street ..and can cause good ..and loose some functions in the same time ..so ..think twice before proceed with it ..If it works good..I would not make it unless is a have to do it matter ..
The firmware can be downloaded from the support site of the manufacturer..
Lenoxx... | Answered on Jan 20, 2011
I will advice you check either of any of this two sites amazon.com or ebay.com to get the replacement part you need for your device.
Take care.
Lenoxx... | Answered on Sep 04, 2010
They could be defective but also the charger could be falsely indicating the batteries are charged when they aren't.
Audio Players &... | Answered 8 hours ago
of course not house calls is not part of this forum
Audio Players &... | Answered Yesterday
This sounds more like a low power situation. The voltage to the unit might be low, and should be measured.
As far as I know, there's no reset for the unit. Disconnecting the power should reset it, if there is one.
Audio Players &... | Answered 2 days ago
Service manual
https://www.manualslib.com/manual/1052795/Luxman-R-113.html
Owners manual
Luxman-R-113-Owners-Manual - vintage hifi
www.vintageshifi.com > repertoire-pdf > pdf > telecharge
PDF and features of your new Luxman R-113. This AMIFM stereo receiver incorporates the latest in high technology features, such as auto seek tuning, 20 random ...
Try a full reset also check fuses sharp usually have two
Audio Players &... | Answered 3 days ago
Lenoxx Electronics CD-88 Personal CD Player Logo
1 questions posted
Top Lenoxx Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
matt
matt
Are you a Lenoxx Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Lenoxx Electronics Audio Players & Recorders
Most Popular Question
need owners
  • Audio Players & Recorders
