20 Most Recent HP Jornada 520 Questions & Answers
visit latest.com/user-reviews/pda-reviews/hp-jornada-520/... -
HP Jornada 520 • Answered on Feb 15, 2010
The HP Jornada 520 Series Pocket PC has been discontinued, and some of the accessories may be difficult to locate. They may be available in one of the following ways:
The Part No. for your Serial Cable = F1819A
Hp Internal Crew No. for your Cable = F1798-80014
Regards,Waqar.
HP Jornada 520 • Answered on Aug 16, 2009
Try this link that describes the error you are seeing... http://support.microsoft.com/default.aspx?scid=kb;EN-US;q271300&GSSNB=1
HP Jornada 520 • Answered on Sep 14, 2005
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
HP Jornada 520 • Answered on Sep 12, 2005
Have a look at the user manual for precise instructions.
HP Computers &... • Answered on Apr 03, 2021
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY. Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
Power up your router and printer. Use the setup software supplied with your printer or download it from Hp.com. Press the key combination to open the WPS on the printer, varies with model; read your user manual, press WPS on the router when prompted.
HP Computers &... • Answered on Mar 26, 2021
Yes you can as long as the type of HDD that you are going to add is supported by your motherboard..
HP Computers &... • Answered on Mar 13, 2021
what PC, the pc has a name and model number? and the light has a name. that number decodes to USB Desktop keyboard. COMPAQ my guess is that is the power lamp , if you dont like power on then use black paint or electricians tape to black it out. https://h30434.www3.hp.com/ start the computer, in windows press F1 in the box type keyboard. numlock , caps lock, USB poweroK somethiing like this is the LED order top right.
HP Computers &... • Answered on Mar 09, 2021
Kathy, if you want help with this go here: Bleepingcomputer.com I am a regular there and there are those who have been in IT for a living as I have. You aren't going to get any help here.
HP Computers &... • Answered on Feb 23, 2021
First start is to download the support assistant from HP and run it HP ENVY 15 3040nr Notebook PC Software and Drivers
HP Computers &... • Answered on Feb 09, 2021
You must run Win ZP and download the drivers from your System Disk that was supplied when you purchased your machine.
If your camera isn't working, or if you see a message that says "No camera found": Turn off your Chromebook, then turn it back on. Try using the camera in another app, like Hangouts. If it works in that app, uninstall the app where it doesn't work, then reinstall it.
Fix hardware and system problems - Chromebook Help
HP Computers &... • Answered on Feb 08, 2021
Hold the right shift key for 8 seconds to lock and unlock the keyboard?
HP Computers &... • Answered on Feb 01, 2021
From the Hp web site.
HP Computers &... • Answered on Jan 24, 2021
Larry always posts up there ^^^ , when I should be down here! Great answer Larry Ng.
  • Emmanuel Jan 20, 2021It's doesn't indicate power on, but it comes on..after showing d hp logo when it goes to starting windows it trips off...the when put on again it's requesting to lunch start up repair
  • Larry Ng Jan 20, 2021 the 620 is old and we know them well here. PC's trip off for 20 reasons, that is a fact. and you will not guess 20 times right>? so we test the PC to find cause. true. or get a repair show to fix it like 99% do. are you handy with tools, and willing to buy parts or a meter? IDK why you ask this, ? not told. just want 20 guesses here? that? HP 620 NOTEBOOK right? ????? clear as day over 10 years old 2010 made most are. hp has no service guide like dell have. Dell is best.! (do not buy HP) age is first , with any savvy tech, we see age first, age tells a tech what might be wrong. easy. (and sets the path of actions) the cause is 2 fold, (tech) power overload or overheating. 1: the big huge battery is removed first. run on AC power pack only not that bad and now shorted out huge bad boy battery even run like this FOREVER if that is you bag. 2: next the RTC coin cell battery is now dead a $1 part, and when dead no PC can boot. and BIOS goes NUTS, and random. 3: YouTube covers dismantle to RTC coin watch it. 4: overheating we run apps on any PC to see if CPU is not too hot, if yes we clean the PC out fully of all lint or it will always overheat.https://pcdied.com/overheated.html 5: overloading power, this is where the 20+ count comes in to play, 20 things inside any PC on average can in fact short out and the power regulators inside see that and shut down and the PC goes dead. we do the strip down test to find that. https://pcdied.com/PSU/strip-down-testin... I bet you are not game for all that. most are not, that is why PC shops excel. you have 3 choices besides trade up. 1: get the shop to fix it. 2: gue$$. 3: or test. your call.
  • Larry Ng Jan 20, 2021 if PC stays on, bad HDD is next fail. like clock work , normal failures are known. batteries first then HDD. or simply packed full of lint alike all are 10 years old, no kidding, packed.
  • Anonymous Jan 20, 2021 trips off means 1:fans dead 2: screen dead 3: all LED dead. 4: silent, right? and holding power button for 10 seconds and released at end fails. 5: and fails with big battery dropped out fully. there is start, we can do this 20 steps at a time. until TRUE cause is found. RTC coin replaced is next. seen as coin cell socket holder (nice) just the opposite side from DDR ram bank. seen here. see silver coin? left side.? https://youtu.be/OKQb4oR_WUM?t=333
HP Computers &... • Answered on Jan 21, 2021
Re install the correct driver.
HP Computers &... • Answered on Jan 20, 2021
HP Jornada 520 Logo
Popular Tags
11 questions posted
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Jornada HP
  • Jornada HP
Most Popular Question
screen broken need entire
  • Computers & Internet
