20 Most Recent
HP Jornada 680 Pocket PC Questions & Answers
Welcome to Fixya. Serial port are not available on modern computers because they are using USB, Firewire, eSata connection which is faster transfer rate than serial cables. There are connectors or cables out in the market or local computer stores like usb to serial adapter that you can use to connect the Jornada 680
Thanks for using Fixya.
HP Jornada 680...
Answered
on Jun 25, 2011
http://home.freeuk.com/gogmagog/installation_guides/6xx/installation_guide_memory_680_680e_690_690e.html
HP Jornada 680...
Answered
on Jun 26, 2008
Sounds like a loose connector inside, I had a similar problem after I took my 680 apart to replace a cracked screen. It took a few more dismantlings and re-assemblings until it settled down. You should also check the state of the button cell battery.
HP Jornada 680...
Answered
on Sep 12, 2005
Hi. Put your desktop ip-address into your network card wins-address field (on your Jornada) Works for me :)
HP Jornada 680...
Answered
on Sep 12, 2005
To get to pocket MSN and Hotmail...
http://mobile.msn.com/pocketpc/
HP Jornada 680...
Answered
on Sep 12, 2005
Whats the operative version that you have? Maybe be a hardware issue but better first try to update what you can. Please update.
HP Jornada 680...
Answered
on Sep 12, 2005
There is a program called Tascal Regedit 7.0 which helps to get the touchscreen software working again.
HP Jornada 680...
Answered
on Sep 12, 2005
User a Microsoft ERD boot disk such as ERD 6.5 and use the offline password reset tool. This will only work on the local accounts.
HP Computers &...
Answered
15 hours ago
Have a look at the user manual for precise instructions.
HP Computers &...
Answered
on Apr 03, 2021
HARD DISK MAINTENANCE TO KEEP COMPUTER RUNNING EFFICIENTLY. Hard disk maintenance should be carried once a month to make your computer run efficiently. This removes redundant and temporary files, recovers disk space and speed up hard disk access. Disk Cleanup should be done first - Click My Computer - then right click on the C drive then click Properties, then click Disk Cleanup - let it examine the C drive then it will calculate the amount of disk space it will recover, tick all the boxes to recover the maximum disk space and then Click OK and then Yes to perform these actions. If you have a D drive then repeat these steps on this drive too. Next the C drive needs to be Defrag. This process converts fragmented files into continuous files and this speeds up disk access and makes the hard disk not work as hard. Click on Start - All Programs - Accessories - System Tools - Disk Defragmenter - click to highlight the C drive and click Analyse - then click Defragment. When this is completed repeat these steps for the D Drive if you have a D drive. Disk Cleanup and Defrag can take a long time to complete, especially if these tasks have not been for a long time.
HP Computers &...
Answered
on Apr 03, 2021
Power up your router and printer. Use the setup software supplied with your printer or download it from Hp.com.
Press the key combination to open the WPS on the printer, varies with model; read your user manual, press WPS on the router when prompted.
HP Computers &...
Answered
on Mar 26, 2021
Yes you can as long as the type of HDD that you are going to add is supported by your motherboard..
HP Computers &...
Answered
on Mar 13, 2021
what PC, the pc has a name and model number?
and the light has a name.
that number decodes to USB Desktop keyboard. COMPAQ
my guess is that is the power lamp , if you dont like power on
then use black paint or electricians tape to black it out.
https://h30434.www3.hp.com/
start the computer, in windows press F1
in the box type keyboard.
numlock , caps lock, USB poweroK
somethiing like this is the LED order top right.
HP Computers &...
Answered
on Mar 09, 2021
Kathy, if you want help with this go here:
Bleepingcomputer.com
I am a regular there and there are those who have been in IT for a living as I have. You aren't going to get any help here.
HP Computers &...
Answered
on Feb 23, 2021
You must run Win ZP and download the drivers from your System Disk that was supplied when you purchased your machine.
HP Computers &...
Answered
on Feb 09, 2021
