20 Most Recent
HP Jornada 540 Pocket PC Questions & Answers
If you do a new, clean install of XP in 2018, one would be missing hundreds of updates from Microsoft that would be very hard if not impossible to get. Some of those updates might apply to software that you want to use in conjunction with Windows XP. And if it is an older PC, you might not be able to find driver support for the particular make/model, and XP might not have the drivers you need. How many times have you heard someone say, "I just reinstalled XP, but now I am missing drivers?"
This could be part of your trouble, because even if your XP updated all the way up to April 2014, you could still be missing HP updates provided by HP/Microsoft through Windows Update.
Since Microsoft has not supported XP since April 2014, I would recommend not using it anymore in 2018.
HP Jornada 540...
Answered
on Jan 29, 2018
why not ask HP,
they had books on it but is obsolete this device. its old.
and zero support. (what good is it ?) over CELL smart phone.
here is real HP
ask here, maybe some wild guy has manual squirreled away.
https://h30434.www3.hp.com/
ask both questions.
HP Jornada 540...
Answered
on Aug 26, 2017
check the bios settings and set the multiboot settings.........
HP Jornada 540...
Answered
on Jul 14, 2011
Befor installation you need to follow the following steps
1. Start your laptop and press F10 continuously to go to BIOS setup.
2. Go to "System Configuration" -> "Device Configurations"
3. Set "SATA Native Mode" to Disabled.
4. Start the installation while keeping a finger on "F7" key.
5. After some time there will be continuous beeps.
6. Remove your finger for sometime and then continuously press "F7" key till the beeps are repeated. This is done to disable your BIOS ACPI.
7. And then do you normal Xp installation.
8. This should do
HP Jornada 540...
Answered
on May 11, 2011
Just do this
8. This should do.
HP Jornada 540...
Answered
on Sep 20, 2009
No, sorry, the Jornada 540 does not have Pocket Access on it. The Jornada 720 does, however...
HP Jornada 540...
Answered
on Sep 12, 2005
Sounds like the shock from being dropped may have caused some internal connections to the screen to become loose causing the stripes or blank screen. It is also possible something might have been damaged. It sounds more like a loose connection and not any damage, but I don't know for sure. My suggestion would be to get it looked at by a professional.
HP Jornada 540...
Answered
on Sep 12, 2005
As best as I reemember there is no way to do it as the OS and apps are burned into ROM. The 568 was the only Jornada that could be software updated.
HP Jornada 540...
Answered
on Sep 12, 2005
Sorry, no can do. The only thing you can do is sync it with Outlook and use the sort options there.
HP Jornada 540...
Answered
on Sep 12, 2005
Sorry, the OS on the Jornada 540 is in ROM and cannot be changed.
HP Jornada 540...
Answered
on Sep 12, 2005
First I'd try a hard reset (tiny red button at the back), if that doesn't help, it is likely to be the battery.
HP Jornada 540...
Answered
on Sep 12, 2005
The Jornada 540 should have come with Outlook 2000. It works fine in Windows XP. When you Sync your computer and Jornada 560, the contact information should transfer from one to the other until both have the same contact information.
Under the Tools pulldown on Activesync, select Options. Sync Options allows you to sync your Contacts by checking the box next to it. The next time you sync, all of your contacts from your 560 will be in your Outlook.
When you get your battery replaced, just sync again and all of the contacts in your Outlook should transfer back to your 560.
The other option is to get a Compact Flash memory card and backup your info onto that. Its much easier. Simply restore your info from your memory card when the battery is replaced.
Hope that helped you.
HP Jornada 540...
Answered
on Sep 12, 2005
Sorry, the Jornada 540 has the OS in ROM and is not upgradable. Additionally, the 540 uses the SH3 processor which Microsoft does not support in the more recent versions of the OS.
HP Jornada 540...
Answered
on Sep 12, 2005
